BT Baby Monitor Pacifier
Quicklinx: 7HGGWS00 Mfr#: 058298
The Baby Monitor Pacifier comes with lightshow, MP3 connection, HD-sound and a wider range of lullabies - giving you even more peace of mind with your baby!
The Pacifier comes with a starry night projected light show combined with a wide-range of lullabies (from Mozart to `twinkle, twinkle' which have been proved to calm and relax babies. It also has an MP3 connection so that you can play the baby its favourite song -or yours!
Like the BT Baby Monitor 200 and 250, the Baby Monitor Pacifier has crystal clear HD sound, and a talk-back feature. It has a huge range of 50m indoors and 300m outdoors, and the temperature-changing nightlight on the monitor changes colour depending on the room temperature so that you can check at a glance. All of our monitors come with various modes of alerting you to sounds in the babies room - full sound monitoring, beeping, vibration, or flashing lights.
So when you want to watch TV or make the dinner in the other room, but want total reassurance that your baby is safe and sound in the cot, the new BT Baby Monitor Pacifier is the Baby Monitor for you.
Main Features
  • Digital sound quality with high definition sound lets you hear your baby breathe, gurgle, snuffle or cry with complete clarity
  • Wireless range of up to 300m outdoors and up to 50m indoors (in ideal conditions, where there is a clear line of sight between the units) - giving you the freedom to move around with clear reception and no interference from other baby monitors
  • Out of range warning
  • Link light provides continuous confidence that the Parent unit is receiving a signal from the Baby unit and will alert you if the link is lost
  • 19 Songs or play your own music from the Baby unit
  • Talk Back feature lets you instantly reassure and calm your baby
  • Adjustable nightlight brightness on Baby unit
  • Lightshow with adjustable brightness on Baby unit
  • Room temperature monitor
  • Crying alert on Parent unit
  • Feed timer and alert on Parent unit
  • Torch on Parent unit
BT Baby Monitor - baby monitoring system
Baby monitoring system
Hi-Definition Sound
Lightshow
Auxillary MP3 input
Backlit Display
Blue
Torch
Temperature Changing Nightlight
Travel Bag
White/Purple
Sound Sensitivity LEDs
Wipeable Keys
Paging
Low Battery Alert
Battery Type
NiMH
Belt Clip
Volume Control
Wall Mount
No
Clock
No
Vibrating Alert
Timer
Talk Back
Resources
The following resources are available for the BT Baby Monitor Pacifier
