Top features - Twinkly projected lightshow featuring stars and moons to help your little one drift off to sleep
HD Sound for crystal clear audio so sensitive you can hear your little one breathing
Temperature display lets you know how hot or cold it is in the nursery
18 lullabies including classical, nursery rhymes, white noise, nature and womb sounds
Charging dock, adjustable night light and torch
The BT Digital Baby Monitor 350 Lightshow gives you peace of mind when your baby is resting or sleeping peacefully. There are a host of features to help your baby drift off to sleep and let you get on with things.
Projected Lightshow and lullabies
A built in light show projects dreamy images of stars and moons onto the ceiling. The gentle shapes help calm your baby. The 18 built in lullabies feature classical music and traditional nursery rhymes - from Mozart to `Twinkle, twinkle'. It also a white noise generator with specially tested sounds that help babies sleep including ocean waves, simulated womb sounds and even a hairdryer.
HD Sound and talk back
Like the other monitors in BT's range, the BT 350 Lightshow has crystal clear HD sound and a talk-back feature. The two way talk-back allows you to calm your baby when you're not in the room, while the Hi-definition Sound is sensitive enough to pick up babies breathing.
Night light and torch
Once your baby is asleep, you won't want to wake him or her up. The adjustable nightlight and torch functions allow you to find your way around baby's room without having to turn on the main light.
Huge Range
It has a huge range of up to 50m indoors and 300m outdoors, so you can be sure to always be in contact as you move around your home.
Other features
Other features include a mute function, crying alert, page to help you find the parent unit, low battery alert and out of range alert. The parent unit is wipe clean with rubberised keys.
So why BT for your baby monitor?
BT has a long history with baby monitors. Our previous monitors have won almost every award under the sun, including the prestigious Which? Best Buy, Mother & Baby Gold and Prima Baby & Pregnancy Platinum.
BT has been the bestselling digital audio baby monitor brand every year since 2010 (Source: NPD 2013).
The BT 350 Lightshow was designed in the UK. We work with `real' mums and dads throughout our product development to make sure we get the product just right.
So when you want to watch TV or make the dinner in the other room, but want total reassurance that your baby is safe and sound in the cot, the new BT 350 Lightshow is the Baby Monitor for you.
