BT Baby Monitor 200
BT Baby Monitor 200
Quicklinx: 79MWWS00 Mfr#: 058296
UK'S No.1 Selling Digital Baby Monitor Brand
BT Baby Monitor 200
A great baby monitor can make a real difference. It'll help make life easier for you, and give you complete reassurance by keeping you close to your baby, even when you're away.
One of the best buys you can make for you and your baby is a baby monitor. The best monitors have grown up and adopted all sorts of new technology, so you'll be amazed by what they can do.
  • Digital DECT technology
  • Hi-definition sound
  • Mute low/mute all
  • Talkback
  • Nightlight
  • Travel bag
  • Volume control
As featured in
White/Purple
Sound level indicator
Power on/off
Nightlight
Sensitivity Control
Battery Type (parent)
NiMH
Belt Clip
No
Volume Control
Battery Size (parent)
AA
Wall Mount
No
Mute
Battery Capacity (parent)
1300mAh
Clock
No
Vibrating Alert
No
Timer
No
Temperature Alert
No
Battery Type (baby)
Alkaline
Out of range alert
Paging
Battery Size (baby)
n/a
Talk Back
Baby Unit (Weight)
134g
Parent Unit (Weight)
92g
Charger (Weight)
41g
Baby Unit (Dimensions)
5.7 x 11 x 11.9 cm
Parent Unit (Dimensions)
4.5 x 6.6 x 9.4 cm
Charger (Dimensions)
3.8 x 8.6 x 6.9 cm
Country of manufacture
China
Resources
The following resources are available for the BT Baby Monitor 200
