BT Baby Monitor 150
BT Baby Monitor 150
Quicklinx: 4M8PWS00 Mfr#: 045299
The BT Baby Monitor 150 is not only a hit with many thousands of parents, it's also won a number of awards for its combination of crystal clear sound, reliability, features and value for money.
Awards
Mumsnet Best Award 2011
Winner - Best Baby Monitor - Mother & Baby magazine 08/09
Best Buy - Baby Monitor - Which Magazine Sept 08
Reasons to have BT Baby Monitor:
The BT Baby Monitor 150 provides advanced features such as Mp3 plug-in and integrated thermometer, DECT digital technology, polyphonic lullabies, rechargeable batteries and a torch on the parent handset - High definition sound gives you a new level of sound quality - so real it sounds like your baby is in the room with you, MP3/CD audio source* lets you play your baby's favourite music at bedtime to help them sleep. With a sleek stylish design, not just practical and packed with features for your peace of mind, but with its sophisticated clean lines and styling it looks great in any room and you'll be eager to show it off - Furthermore the Vibrate function gives you peace of mind without the disturbance of standard baby monitors.
*Please note a separate audio device (such as an mp3 or cd player) is required
  • Digital DECT technology with Hi-Def sound
  • Rubber key zones on both units
  • Mains or battery powered
  • Rechargeable batteries in parent unit
  • Portable parent unit
  • Interchangeable power adapters (X2)
  • sound level indicator LED array
  • parent talk back
  • Mute function on parent unit
  • Vibrating alert on parent unit
  • Auxiliary input for external audio sources
  • parent voice recording on baby unit
  • Torch on parent unit
  • Room temperature monitor
  • Backlit b/w dot matrix LCD screen
  • Timer/alerts on parent unit
  • Nightlight with adjustable brightness
  • Illuminated key zone on baby unit
  • Multiple Polyphonic lullabies
  • Fully adjustable volume and sensitivity
  • Range up to 300m outdoors & 50m indoors(+)
  • Travel bag
  • Belt clip
  • Out-of-Range warning
  • battery low indicator
BT Baby Monitor 150 baby monitoring system - DECT
Baby monitoring system
Max Talk Range
300 m
Vibrating Alert
Display
LCD display - monochrome - backlit
Rechargeable
Radio System
DECT
Max Talk Range
300 m
Vibrating Alert
Controls
Volume button
Indicators
Low battery
Radio System Features
Audible Call Alert
Additional Functions
Clock, thermometer, alarm, nightlight
Additional Features
Out of range alert, Babyphone (room monitoring)
Display
Backlit
Aerial
Internal
Audio line in
Charging stand, carrying case, belt clip, power adapter
Charging stand + power adapter
Rechargeable
Resources
The following resources are available for the BT Baby Monitor 150
