BT Advanced Phone Z - Single
Quicklinx: G6D2WS00 Mfr#: 090642
Type: Cordless phone
Handsets Included: 1
Answer Machine: Yes
Nuisance Call Blocker: Yes
Mounting: Table-top
Select:
33 In Stock
£41.66 ex VAT
£49.99 inc VAT
Express delivery Delivered on Tuesday
Advanced Phone Z with 100% nuisance call blocking and answer machine
The Advanced Phone Z, powered by trueCall’s award winning technology. Have complete control over which calls you want to take and those you want to block.
Nuisance Call blocking features
Avoid unwanted calls. Block up to 1000 specific numbers or use Do Not Disturb to silence your calls.
Easy set up and great sound quality
Get the most out of your phone straight away with our easy to use menu. And enjoy high quality clear calls.
  • Block up to 1000 numbers
  • Excellent sound quality
  • Easy set up
  • Handsfree speaker
  • Long range reception, up to 300m outdoors, 50m indoors
  • 22 hours of talking OR 240 hours standby time
  • See and hear if you have a second call waiting
  • Easy to read screen shows when you have messages
  • Dedicated Call Block Button
  • Save up to 200 contacts
  • Redial any of the last 30 calls you made
  • Record up to 30 minutes of messages
  • 1.8 inch monochrone black and white screen
  • 12 months guarantee
BT Advanced Phone Z Single - cordless phone - answering system with caller ID
Cordless phone answering system with caller ID
Total Number of Wireless Handsets
1
Cordless Phone Standard
DECT\GAP
Speakerphone
Call Services
Caller ID, Call Waiting, Call Transfer, Call Block, Call screening
Display
LCD display - monochrome - Yes
1
Phone Features
DECT\GAP
Call Services
Caller ID Type
Caller ID
Max Handset Operating Distance
50 m
Max Handset Operating Distance (Outdoor)
300 m
Dialer Location
Handset
Conference Call Capability
Speakerphone
Volume Control
Indicators
Visual ringer light, call waiting indicator
Additional Functions
Call timer, built-in clock, Alarm, Intercom, remote access, keyboard lock
Phone Memory
Phone Directory Capacity
200 names & numbers
Caller ID Memory
30 names & numbers
Answering System
Recording Capacity
30 min
Display
Display Location
Handset
Diagonal Size
1.8"
Backlit
Placing / Mounting
Table-top
AAA type
750 mAh
Nickel Metal Hydride
Talk Time
22 h
Standby Time
240h
Dimensions & Weight (Base)
11.4 cm
9.3 cm
4.6 cm
123 g
Dimensions & Weight (Handset)
5.2 cm
3.5 cm
17.6 cm
119.4 g
Dimensions & Weight (Power Adapter)
8.4 cm
7.8 cm
4.1 cm
46.2 g
Answer Machine: Yes
Mounting: Table-top
Big Button: No
Brand: BT
