BT Advanced Phone - Three Handsets
Quicklinx: D9R6WS00 Mfr#: 090640
Type: Cordless phone
Handsets Included: 3
Answer Machine: Yes
Nuisance Call Blocker: Yes
Mounting: Table-top
Select:
More than 50 on order, no confirmed delivery date
£58.33 ex VAT
£69.99 inc VAT
Advanced Phone with 100% call blocking and answer machine
  • trueCall virtual assistant filters and announces all unknown calls
  • Handsfree speaker
  • Excellent sound quality
  • Automatically share contacts between handsets
Call blocking
  • Incorportates award-winning trueCall call blocking technology
  • Block 100% nuisance calls*
  • Save contacts get straight through
  • Virtual assistant filters and announces all unknown calls
  • Block 1000 numbers
  • Dedicated call block button
  • Do Not Disturb mode
Key benefits
  • Easy set up
  • Record up to 30 minutes of messages
  • Save up to 200 contacts
  • Handsfree speaker
  • Redial any of the last 30 calls you made
  • Adjust the volume if the caller is too quiet (or too loud)
  • See who's calling before you pick up
  • 1.8 inch monochrome screen
  • Auto-share contacts between handsets
*You must subscribe to a Caller Display service from your network provider for the block nuisance calls feature to work. Charges may apply.
  • Nuisance Call blocking features
    Avoid unwanted calls. Block up to 1000 specific numbers or use Do Not Disturb to silence your calls.
  • Easy set up and great sound quality
    Get the most out of your phone straight away with the easy to use menu. And enjoy high quality clear calls.
BT Advanced Phone Trio - cordless phone - answering system with caller ID + 2 additional handsets
Cordless phone answering system with caller ID + 2 additional handsets
Total Number of Wireless Handsets
3
Cordless Phone Standard
DECT\GAP
Speakerphone
Call Services
Call Waiting, Call Transfer, Call Block
Display
LCD display - monochrome - Yes
Additional Handsets Qty
2
3
Phone Features
DECT\GAP
Call Services
Caller ID Type
Caller ID
Max Handsets Supported
6
Max Handset Operating Distance
50 m
Max Handset Operating Distance (Outdoor)
300 m
Dialer Location
Handset
Conference Call Capability
Speakerphone
Volume Control
Ring Tones
15
Polyphonic Ringer
Handset Locator
Indicators
Visual ringer light
Additional Functions
Call timer, built-in clock, Alarm, Intercom, keyboard lock
Phone Memory
Phone Directory Capacity
200 names & numbers
Caller ID Memory
30 names & numbers
Answering System
Recording Capacity
30 min
Display
Display Location
Handset
Diagonal Size
1.8"
Backlit
Placing / Mounting
Table-top
AAA type
750 mAh
Rechargeable - Nickel Metal Hydride
Talk Time
Up to 1320 min
Standby Time
Up to 240 h
Dimensions & Weight (Base)
8.2 cm
4.3 cm
14.2 cm
121.6 g
Dimensions & Weight (Handset)
5.1 cm
3.5 cm
17.6 cm
123.2 g
Resources
The following resources are available for the BT Advanced Phone - Three Handsets
Answer Machine: Yes
Mounting: Table-top
Big Button: No
Brand: BT
Price Range Ex VAT: 50 - 100
