BT Add-on disc for Premium Whole Home Wi-Fi
Quicklinx: F7BYWS00 Mfr#: 093591
Select:
  • Add-on
  • IEEE 802.11n
Premium Whole Home Wi-Fi Add-on disc
Extend your wi-fi signal even further with any broadband provider
Tri-band technology pushes faster, stronger wi-fi to every corner of your home
The third high-speed channel you get with tri-band allows more devices to connect, and do more at the same time.
Adding an extra disc is perfect for larger homes, those with thick walls or when you need wi-fi in your garage or garden. A maximum of 6 discs can be supported on a network. This disc only works with other Whole Home Premium discs.
Intelligent wi-fi that covers the whole home
Now you can have multiple users streaming TV, films, music and games on any device, in any room, with no dead spots or drop-outs.
  • Adding a disc to your existing Whole Home Premium network gives you full coverage and gets rid of wi-fi dead spots. Our super smart app will locate the best position for your extra disc.
  • Automatically connects your devices to the fastest, strongest signal as you move around.
  • Even with multiple devices connected you won’t lose speed anywhere in your home.
Premium Whole Home Wi-Fi coverage
Standard router coverage
Our free app puts you in control of your home network
100% coverage in minutes
  1. Download the Whole Home Wi-Fi App
  2. Connect one disc to your router
  3. Follow the app guidance to place the other discs around your home
  4. Connect your devices
Bedtime controls
Set schedules to control wi-fi access for individual users or groups of devices to make sure bedtime is free from screen time.
Pause the Internet
Want to get everyone down for dinner? Temporarily pause the internet with one tap. Only want to pause it for the kids? It’s easy to set schedules so individual users or devices get some time offline.
Secure Guest Network
Create a separate network for guests and keep your home network secure. It’s easy to share access details via the app, see which devices are connected and block any you don’t recognise.
BT Premium Whole Home Wi-Fi Add-on disc - radio access point
Radio access point
External
IEEE 802.11ax, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
3-year warranty
Radio access point
External
Tri-band Wireless technology
IEEE 802.11ax 5GHz, 802.11a/n/ac 5GHz, 802.11b/g/n 2.4GHz
Frequency Band
2.4 GHz, 5 GHz
Status Indicators
WPS, starting, connection status
Manageable, firmware upgradable, WPA2 encryption, roaming function, Wi-Fi Protected Setup (WPS), reset button, mobile users support, WPA encryption, band steering, AES encryption, quad-stream (4x4), coloured LED status, self-configuring network
Encryption Algorithm
AES, TKIP, WPA, WPA2, WPS
IEEE 802.11ax, IEEE 802.11ac, IEEE 802.3, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11k, IEEE 802.11ac, IEEE 802.11v
Aerial
Antenna
Internal
Antenna Qty
6
1 x 1000Base-T - RJ-45 (WAN)
1 x network cable
External power adapter
Limited warranty - 3 years
10 - 85%
