Extend your wi-fi throughout your home
These discs only work as an add-on with your other Mini Whole Home Wi-Fi discs
How many discs do you need?
- Smaller homes and flats (1-2 bedrooms) - 2 discs recommended
- Average homes (3-5 bedrooms) - 3 discs recommended
- Large homes (6+ bedrooms) - 3 discs + add-on disc reccomended
- BT Mini Whole Home Wi-Fi Add-on disc - radio access point - Wi-Fi 5
- Radio access point
- Form Factor
- External
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Frequency Band
- 2.4 GHz, 5 GHz
- Performance
- Maximum data rate (2.4 GHz): 300 Mbps , Maximum data rate (5 GHz): 866 Mbps
- Power
- AC 120/230 V (50/60 Hz)
- 12 cm x 12 cm x 5 cm
- 3-year warranty
- 12 cm
- 12 cm
- 5 cm
- Form Factor
- External
- Connectivity Technology
- Wireless
- Data Transfer Rate
- 866 Mbps
- Frequency Band
- 2.4 GHz, 5 GHz
- Performance
- Wi-Fi Rating
- AC1200
- Status Indicators
- WPS, starting, connection status
- Manageable, firmware upgradable, WPA2 encryption, roaming function, Wi-Fi Protected Setup (WPS), reset button, mobile users support, WPA encryption, band steering, AES encryption, quad-stream (4x4), coloured LED status, self-configuring network
- Encryption Algorithm
- AES, TKIP, WPA, WPA2, WPS
- IEEE 802.3, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11k, IEEE 802.11ac, IEEE 802.11v
Aerial
- Antenna
- Internal
- Antenna Qty
- 4
- 1 x 1000Base-T - RJ-45 (WAN)
- Cables Included
- 1 x network cable
- Power Device
- External power adapter
- Voltage Required
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 10 - 85%
