If you work from home, have a small business, are a large call centre or simply wish to free your hands when making calls, the BT Accord 30 is the ideal companion for your corded telephone or telephone system. It comes with a noise cancelling microphone (ideal if you work in a noisy environment) and a simple configuration module which will fit most types of corded telephones. It has a 6 position configuration switch for almost universal compatibility. You can easily switch between the headset and handset, and there is also a useful mute function. The BT Accord 30 has a comfortable 27mm ear cushion, and a neat quick disconnector which allows you to put your caller on hold while you disconnect your headset from your phone. Simply reconnect and continue your call.
High quality, affordable telephone headset with noise-cancelling microphone and amplifier. The BT Accord 30 noise cancelling telephone headset offers universal compatibility at a great price. Now everyone can have the benefits of a quality headset without breaking the bank or having to buy a new phone.
The supplied amplifier puts you in control and allows adjustment of volume, multimedia inputs, mute function, headset to handset function and the configuration switches. The BT Accord 30 can also be used as a multimedia headset.
Key features:
- Noise cancelling microphone - ideal for noisy environments.
- Amplifier included for increased functionality and control.
- Use of a headset can reduce neck, upper back and shoulder tension.
- Increases productivity by freeing your hands whilst on the phone.
Lightweight and comfortable.
Acoustic shock protection.
Amplifier features:
- Switch between telephony and multimedia applications
- Works with all PC sound cards and other audio devices.
Includes six position configuration switch to adapt to most direct-line and system phones. * Powerful stereo / mono output.
Automatic battery saving.
- Operated by 2 x AA batteries or a AC adapter (not supplied).
- Quick switch between headset and handset.
- Mute function.
Contents
- Telephone and multimedia amplifier.
- Comfortable monaural (single ear) headset.
- Comfortable ear cushion.
- Full set-up and usage instructions.
- Microphone foam piece.
- Connection cables.
- Microphone adjustment tool.
- BT Accord 30 - headset - with amplifier
- Product Type
- Headset - wired
- Recommended Use
- Phone, computer
- Headphones Form Factor
- On-ear monaural
- Connectivity Technology
- Wired
- Headphones Technology
- Dynamic
- Sound Output Mode
- Mono
- Microphone
- Boom
- Controls
- Volume
- Bundled with
- Amplifier
- Product Type
- Headset - wired
- 280 g
- Recommended Use
- Phone, computer
- Bundled with
- Amplifier
Audio Output
- On-ear monaural
- Dynamic
- Wired
- Sound Output Mode
- Mono
Microphone
- Boom
Remote Control
- Controls
- Volume
- Cable Details
- Headset cable - 1.55 m
- Battery
- 2 x battery - AA type
