BT Accord 20 Telephone Headset
Customer rating: 5.0* (Write a review)
Quicklinx: 45KBWS00 Mfr#: 024335
If you work from home, have a small business, are a large call centre or simply wish to free your hands when making calls, the BT Accord 20 is the ideal companion for your corded telephone or telephone system. It comes with a noise cancelling microphone (ideal if you work in a noisy environment) and a simple configuration module which will fit most types of corded telephones. It has a 12-position configuration switch for almost universal compatibility. You can easily switch between the headset and handset, and there is also a useful mute function. The BT Accord 20 has a comfortable 27mm leather-look ear cushion, and a neat quick disconnector, which allows you to put your caller on hold while you disconnect your headset from your phone, reconnect and continue your call.
Accessibility Features
With noise-cancelling microphone to reduce interfering background noise. Make and receive calls without having to hold the receiver to your ear. All the benefits of using your phone handsfree but with added benefit of keeping your conversation private.
BT Accord 20 - headset
Headset - wired
Headphones Form Factor
On-ear monaural
Wired
Sound Output Mode
Mono
Microphone
Boom
Controls
Mute
Converse 1100, 1200, 1300; Paragon 450
Headset - wired
13 cm
14 cm
110 g
Audio Output
On-ear monaural
Wired
Sound Output Mode
Mono
Diaphragm
27 mm
Microphone
Boom
Remote Control
Controls
Mute
Cable Details
Headset cable - 1.6 m
BT Converse 1100, 1200, 1300 , BT Paragon 450
Resources
The following resources are available for the BT Accord 20 Telephone Headset
Customer reviews
Write a review for the BT Accord 20 Telephone Headset here!
BT Accord 20 Headset
Reviewed by Barney. Review Posted 10/03/2008
very pleased with this headset although best used with my voip phone directly plugged in. Tried to use the switching box included with another phone on a regular line but cannot get it to work on switch over.
Overall though very pleased with sound quality and comfort.
  • Overall 5*
  • Ease of use 5*
  • Value for money 4*
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
