BT 7660 Single
Quicklinx: GMBYWS00 Mfr#: 109336
Type: Cordless phone
Handsets Included: 1
Answer Machine: Yes
Nuisance Call Blocker: Yes
Mounting: Table-top
Select:
£41.66 ex VAT
£49.99 inc VAT
Express delivery Order within the next 23 hours for delivery on Thursday
Digital Cordless Telephone with Nuisance Call Blocking and Answering Machine
The BT 7660 Cordless Phone makes staying in touch at home easier, with no wires and ease of use, it's the perfect phone for all the family.
Basic call blocking features prevent nuisance calls from interrupting your day, plus its large wireless range means you can walk around the house without the phone signal dropping out. And don’t miss important messages when away from home, you can save up to 60 minutes of messages on the answering machine.
There's also a loudspeaker, and ringer with adjustable volume, and a screen with caller ID, so you can see who's calling before you pick up. The clock also has an alarm function, which makes the BT 7660 perfect for use as a bedside phone.
Not hearing aid friendly
You need to have a Caller Display service from your network provider for the block nuisance calls feature to work. Charges may apply.
The BT 7660 blocks numbers in two separate ways to help you avoid nuisance calls, firstly by type, e.g withheld or international, and also by your choice of specific numbers (you can store up to 100 numbers of your own choice)
DISPLAY
  • Screen backlight - Blue
  • Screen size - 1.6"
  • Screen type - Dot matrix
CALLING
  • Handsfree
  • Caller ID
  • Nuisance call block up to 100 numbers
  • Block by call type
  • Do not disturb button
  • Secrecy feature
  • Call waiting
  • Call log - 20
  • Call timer
FEATURES
  • Answering machine
  • Recording time - 60 minutes
  • Phonebook - 100 contacts
  • Ring tones - 10
  • Clock
POWER
  • Talk time - 12 hours
  • Standby time - 120 hours
BT 7660 Single - cordless phone - answering system with caller ID
Cordless phone answering system with caller ID
Total Number of Wireless Handsets
1
Speakerphone
Call Services
Caller ID
1
Phone Features
Call Services
Caller ID
Caller ID Type
Caller ID
Dialer Location
Handset
Speakerphone
Additional Functions
Do not disturb, Nuisance Call Block, up to 50 call blocking numbers, Alarm
Answering System
Recording Capacity
60 min
Resources
The following resources are available for the BT 7660 Single
Answer Machine: Yes
Mounting: Table-top
Big Button: No
Brand: BT
Stock Status: While stocks last
Stock Status: Clearance
