Digital Cordless Telephone with Nuisance Call Blocking and Answering Machine
The BT 7660 Cordless Phone makes staying in touch at home easier, with no wires and ease of use, it's the perfect phone for all the family.
Basic call blocking features prevent nuisance calls from interrupting your day, plus its large wireless range means you can walk around the house without the phone signal dropping out. And don’t miss important messages when away from home, you can save up to 60 minutes of messages on the answering machine.
There's also a loudspeaker, and ringer with adjustable volume, and a screen with caller ID, so you can see who's calling before you pick up. The clock also has an alarm function, which makes the BT 7660 perfect for use as a bedside phone.
You need to have a Caller Display service from your network provider for the block nuisance calls feature to work. Charges may apply.
The BT 7660 blocks numbers in two separate ways to help you avoid nuisance calls, firstly by type, e.g withheld or international, and also by your choice of specific numbers (you can store up to 100 numbers of your own choice)
DISPLAY
- Screen backlight - Blue
- Screen size - 1.6"
- Screen type - Dot matrix
CALLING
- Handsfree
- Caller ID
- Nuisance call block up to 100 numbers
- Block by call type
- Do not disturb button
- Secrecy feature
- Call waiting
- Call log - 20
- Call timer
FEATURES
- Answering machine
- Recording time - 60 minutes
- Phonebook - 100 contacts
- Ring tones - 10
- Clock
POWER
- Talk time - 12 hours
- Standby time - 120 hours
Nuisance call blocking by number
Block up to 50 numbers and be free from interruption during your day. -
Multiple useful functions
Loudspeaker, caller ID, alarm function and more. -
Hands-free feature
Take calls while your hands are busy or place the phone down while on hold. -
Do not disturb
Silence incoming calls if you're too busy or simply don't want to take them.
- BT 7660 Quad - cordless phone - answering system with caller ID + 3 additional handsets
- Product Type
- Cordless phone answering system with caller ID + 3 additional handsets
- Total Number of Wireless Handsets
- 4
- Speakerphone
- Call Services
- Caller ID
- Product Type
- Additional Handsets Qty
- 3
- 4
Phone Features
- Call Services
- Caller ID
- Caller ID Type
- Caller ID
- Dialer Location
- Handset
- Speakerphone
- Additional Functions
- Do not disturb, Nuisance Call Block, up to 50 call blocking numbers, Alarm
Answering System
- Recording Capacity
- 60 min
