BT 11ac Dual-Band Wi-Fi Dongle 610
Quicklinx: B15NWS00 Mfr#: 080221
  • IEEE 802.11n
What does BT's 11ac Dual-Band Wi-Fi Dongle 610 give you?
BT's 11ac Dual-Band Wi-Fi Dongle 610 has been designed to work with any service provider to make sure everyone can make the most of their broadband around their home. Upgrade your computer or laptop to 11ac Dual-Band Wi-Fi to enjoy the greater speed and reliability offered by your 11ac router. With easy setup, you can experience fast 11ac Dual-Band W-Fi on your device in minutes. The W-Fi Dongle 610 works with 11ac and both single and Dual-Band signals, so get great W-Fi whatever your router.
Works with 11ac and both single and Dual-Band signals, so get great Wi-Fi whatever your router
Everyone loves to be online; and why should you settle for anything other than the complete Broadband experience? With BT's 11ac Dual-Band Wi-Fi Dongle 610, upgrade your laptops and computers to 11ac Dual-Band Wi-Fi and get greater speed and reliability wherever, however and whenever you like. Of course, you will need an 11ac Dual-Band router to get the full speed and reliability benefits.
The 11ac Dual-Band Wi-Fi Dongle 610 is easy to setup and use.
Just plug into an available USB port, follow the easy-to-follow setup guide and start enjoying a great 11ac Dual-Band Wi-Fi experience in minutes.
Benefit from increased speed and reliability
BT's 11ac Dual-Band W-Fi Dongle 610 allows you to realise the full potential provided by your 11ac router, without resorting to a newer laptop or PC. Just take your existing computer, connect the Dual-Band W-Fi Dongle 610 and let your 11ac router show you what it can really do.
The 11ac Dual-Band Wi-Fi Dongle 610 is part of BT's connectivity range, which has been designed to solve all connectivity issues to ensure that everyone can make the most of their Broadband around their home. The range includes Broadband Extenders, Wi-Fi Home Hotspots, W-Fi Extenders and Switches, ensuring that there's a solution for all your connectivity requirements.
1 Year Warranty
Resources
The following resources are available for the BT 11ac Dual-Band Wi-Fi Dongle 610
