Brother RJ-4040 Rugged WiFi Mobile Printer
BATTERY & POWER ADAPTORS ARE NOT INCLUDED. SEE FULL RANGE BELOW
Quicklinx: 9FXNWS00 Mfr#: RJ4040Z1
Type: Printer
Functionality: Printer
Output Type: Colour
Wireless Capability: Wireless, Wired
Technology: Laser
£344.13 ex VAT
£412.95 inc VAT
When you need a portable printing solution that meets all of your workplace demands, you can rely on the rugged RJ-4040 with IP54 drop test rating for fast printing on the move.
Ultra efficient thermal technology means you're always ready to print 4" labels, receipts, quotes and invoices.
Totally dust and waterproof, the rechargeable RJ-4040 is available with a range of add-on accessories that make sure you'll get the most from this durable machine.
And serial, Wi-Fi and USB connectivity mean getting the results you need while you're out in the field couldn't be easier.
  • Fast print speed of up to 5 ips
    Faster transactions can mean less wasted time, higher productivity, and increased customer satisfaction.
  • Tough construction
    IP54 certification and 6 feet drop protection mean that water, dust, or drops won't affect the printer's operation under normal conditions.
  • Versatile functionality
    Prints on labels and receipts from 2 inches wide to 4 inches wide - one mobile printer can be used for different mobile applications.
  • Ergonomic design
    Easy to load media and intuitive interface controls.
  • Low maintenance costs
    Highly reliable direct thermal technology uses fewer moving parts than other printing technologies. Fewer moving parts mean fewer parts to fail.
  • Low consumable costs
    There is no ink or ribbons to replace. The only consumable is the media.
  • Wide range of connectivity options
    USB, serial, and Wi-Fi (802.11 b/g/n).
  • Higher memory capacity
    Larger print buffer for increased throughput and more memory to store optional fonts.
  • 203 dpi resolution
    Ensures compatibility with existing mobile applications.
  • Wide selection of resident and downloadable fonts
    Enhance your output with Brother's wide selection of fonts.
  • Support for the major linear and 2D barcodes
    Ensures compatibility with existing applications and provides the latest technology for more applications.
  • Genuine Brother media
    Available in standard, premium, and weatherproof receipt paper, and paper labels to meet most mobile application needs.
  • Fanfold media capability
    External media slot in the back of the printer for warehousing applications.
Brother RuggedJet RJ-4040 - label printer - B/W - direct thermal
Printer Type
Label printer - direct thermal - B/W
Portable
850 g
Max Media Size
Roll (11.8 cm)
Print Speed
Up to 127 mm/sec
Max Resolution (B&W)
203 x 200 dpi
USB, serial, Wi-Fi(n)
RAM Installed (Max)
32 MB
Flash Memory Installed (Max)
16 MB
Language Simulation
EPSON ESC/P, ZPL
Media Type
Labels, receipt labels
Print server - IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Microsoft Windows XP, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows CE 5.0, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2008, Microsoft Windows Mobile 5.0 or later, Android 2.2 or later
1-year warranty
16.2 cm x 7.7 cm x 17.6 cm
Printer Type
Label printer - direct thermal - monochrome
Printer
Print Speed
Up to 127 mm/sec
Wireless
203 x 200 dpi
Language Simulation
EPSON ESC/P, ZPL
RAM
RAM Installed (Max)
32 MB
Flash Memory
Flash Memory
16 MB
Media Handling
Media Type
Max Media Size
Roll (11.8 cm)
Media Sizes
Roll (5.1cm), Roll (11.8 cm)
Max Printing Width
104 mm
Max Printing Length
3000 mm
Roll Maximum Outer Diameter
58 mm
Media Feeders
1 x manual - 1 roll - Roll (11.8 cm)
Print server
1 x serial , 1 x USB
Belt clip
IP54
Software Included
Drivers & Utilities
Limited warranty - 1 year - carry-in
20 - 80% (non-condensing)
16.2 cm
7.7 cm
17.6 cm
850 g
9FXN Brother PA-CD-600WR Car Adaptor for RJ-4040 Rugged WiFi Mobile Printer In Stock £22.14
9FXN Brother PA-SS-4000 Carrying Strap for RJ-4040 Rugged WiFi Mobile Printer In Stock £31.23
Type: Printer
Output Type: Colour
Wireless Capability: Wired
Technology: Laser
Max Print Speed: [N/A]
Max Paper Size: Roll (11.8 cm)
Brand: Brother
