Our RJ-3000 Series portable printers are smaller and lighter than ever before. They provide the perfect on-person device for mobile workers needing a 2" or 3" printing solution - from emergency services and field sales to delivery drivers, engineers and traffic wardens. The RJ-3050 can print up to 3" receipts, quotes and labels on the spot. They're also fast, saving everyone valuable time and money.
Its thermal printing technology means users don't have to worry about ink or toner, while its IP54 certification-the toughest tests against dust and water-means you are assured of its continued reliability whatever the conditions. Plus ZPL compatibility also allows existing applications for label/receipt printers to work with the RJ device.
                Fast print speed of up to 5 ipsFaster transactions can mean less wasted time, higher productivity, and increased customer satisfaction.
                Tough constructionIP54 certification and 6 feet drop protection mean that water, dust, or drops won't affect the printer's operation under normal conditions.
                Versatile functionalityOne mobile printer can be used for different mobile applications.
                Ergonomic designEasy to load media and intuitive interface controls.
                Low maintenance costsHighly reliable direct thermal technology uses fewer moving parts than other printing technologies. Fewer moving parts mean fewer parts to fail.
                Low consumable costsThere is no ink or ribbons to replace. The only consumable is the media.
                Higher memory capacityLarger print buffer for increased throughput and more memory to store optional fonts.
                203 dpi resolutionEnsures compatibility with existing mobile applications.
                Wide selection of resident and downloadable fontsEnhance your output with Brother's wide selection of fonts.
                Fanfold media capabilityExternal media slot in the back of the printer for warehousing applications.
- Brother RuggedJet RJ-3050 - receipt printer - B/W - direct thermal
- Printer Type
- Receipt printer - direct thermal - B/W
- Form Factor
- Portable
- 610 g
- Max Media Size
- Roll (8 cm)
- Min Media Size (Custom)
- 25 mm
- Max Media Size (Custom)
- 80 mm
- Print Speed
- Up to 127 mm/sec
- Max Resolution (B&W)
- 203 dpi
- Interface
- USB 2.0, Wi-Fi(n), Bluetooth 2.1 EDR
- RAM Installed (Max)
- 32 MB
- Flash Memory Installed (Max)
- 32 MB
- Language Simulation
- EPSON ESC/P, ZPL II, EPSON ESC/P Raster, Comtec Printer Control Language (CPCL)
- Barcodes
- Code 39, GS1 DataBar, QR code, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Codabar, Code 128, Postnet, PDF417, Data Matrix, ITF, GS1 DataBar Expanded, GS1 DataBar Limited
- Media Type
- Labels, receipt paper
- Fonts
- Helsinki, Letter Gothic Bold, Gothic
- Networking
- Print server
- Battery
- Required 1 Lithium Ion Included Qty 1
- System Requirements
- Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2008, Windows 8, Microsoft Windows Server 2012, Android 2.3 or later, Apple iOS 5.0 or later, Microsoft Windows Server 2012 R2, Windows 8.1
- 3-year warranty
- 113 cm x 18.6 cm x 8 cm
- Printer Type
- Receipt printer - direct thermal - monochrome
Printer
- Print Speed
- Up to 127 mm/sec
- Connectivity Technology
- Wireless
- Interface
- 203 dpi
- Fonts
- Barcodes
RAM
- 32 MB
Flash Memory
- Flash Memory
- 32 MB
Media Handling
- Media Type
- Max Media Size
- Roll (8 cm)
- 25 mm
- 80 mm
- Media Sizes
- Roll (8 cm), Roll (2.5 cm)
- Max Printing Width
- 72 mm
- Max Printing Length
- 1 m
- Media Thickness Range
- 0.058 mm - 0.17 mm
- Roll Maximum Outer Diameter
- 66 mm
- Roll Core Diameter
- 12.7 mm
- Media Feeders
- 1 x manual - 1 roll - Roll (8 cm)
- Networking
- Print server
- Connections
- 1 x USB 2.0 - 4 pin mini-USB Type B
- Included Accessories
- Belt clip
- IP54
- Power Device
- No power supply
- Lithium Ion
- Required Qty
- 1
- Included
- 1
- Run Time (Up To)
- 5300 pages
- OS Required
- Limited warranty - 3 years
- -10 °C
- 50 °C
- 10 - 90% (non-condensing)
- 113 cm
- 18.6 cm
- 8 cm
- 610 g
