The Brother QL-500A Label Printer has taken label printing to a new level. Whether you need one label or many labels, it's the fastest, easiest and most versatile way to print labels directly from your PC. Perfect for printing address & shipping labels, banners & signage, this machine has unique label flexibility and can print on both die-cut peel-off labels or continuous length tape.
- Brother QL-500A - label printer - B/W - direct thermal
- Printer Type
- Label printer - direct thermal - B/W
- 1.3 kg
- Localisation
- United Kingdom
- Max Media Size
- Roll (6.2 cm)
- Max Media Size (Custom)
- 62 mm
- Print Speed
- Up to 90 mm/sec - B/W - Roll (6.2 cm) , Up to 50 labels/min - B/W - Roll (6.2 cm)
- Max Resolution (B&W)
- 300 dpi
- Cutter
- Interface
- USB
- Media Type
- Labels, continuous forms, CD/DVD labels
- Compatible Tapes
- DK tape
- System Requirements
- Microsoft Windows 98 Second Edition, Microsoft Windows 2000 Professional, Microsoft Windows Millennium Edition, Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Apple MacOS X 10.1 - 10.4.7
- 3-year warranty
- 14.6 cm x 19.6 cm x 15.2 cm
- Printer Type
- Label printer - direct thermal - monochrome
- Localisation
- United Kingdom
Printer
- Print Speed
- Up to 90 mm/sec - B/W - 300 dpi - Roll (6.2 cm) , Up to 50 labels/min - B/W - 300 dpi - Roll (6.2 cm)
- Built-in Devices
- Cutter
- Connectivity Technology
- Wired
- Interface
- USB
- 300 dpi
- Cutter
Media Handling
- Media Type
- Compatible Tapes
- DK tape
- Max Media Size
- Roll (6.2 cm)
- 62 mm
- Media Sizes
- Roll (2.9 cm), Roll (1.2 cm), Roll (6.2 cm)
- Max Printing Width
- 59 mm
- Media Feeders
- 1 x manual - 1 roll - Roll (6.2 cm)
- Connections
- 1 x USB - 4 pin USB Type B
- Cables Included
- 1 x USB cable
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- OS Required
- Additional Requirements
- CD-ROM, SVGA monitor, USB port
- System Requirements Details
- Windows 98 SE - Pentium - 266 MHz - RAM 64 MB - HD 70 MB , Windows 2000 Pro - Pentium - 266 MHz - RAM 128 MB - HD 70 MB , Windows XP Home Edition - Pentium - 266 MHz - RAM 128 MB - HD 70 MB , Windows XP Professional - Pentium - 266 MHz - RAM 128 MB - HD 70 MB , Windows ME - Pentium - 266 MHz - RAM 64 MB - HD 70 MB
- Limited warranty - 3 years - carry-in
- 10 °C
- 35 °C
- 20 - 80%
- 14.6 cm
- 19.6 cm
- 15.2 cm
- 1.3 kg
Ink (8)
Brother Large Address Labels | In Stock | £7.96 |
Brother DK Continuous White Labels | In Stock | £13.32 |
Brother Shipping 62 x 100mm 300 Labels | In Stock | £11.48 |
Brother P-TOUCH Yellow Paper- 62mm | In Stock | £13.18 |
Brother p-touch White Paper - 62mm | In Stock | £12.04 |
Brother Paper Roll (6.2 cm x 30.5 m) | In Stock | £10.46 |
Brother Non Adhesive Paper Tape 54mm | In Stock | £12.01 |
Brother DKBU99 Printer Label Cutter (2 Pack) | In Stock | £6.94 |
Other bundles (2)
Brother BROTHER DK-22212 TAPE 62MM WH. | In Stock | £34.24 |
Brother P-TOUCH TAPE PAPER 29MMX30.48M | In Stock | £6.27 |
