The flexible label printer which integrates with your connectivity requirements
Print labels from your PC, Mac, smartphone or tablet using USB, Ethernet, Wi-Fi and Bluetooth. Or alternatively use it in standalone mode by selecting and printing labels previously designed and uploaded to the memory, using the integrated backlit LCD display. When used with special rolls, you can print labels that can contain both black and red print without needing any ink. And when you can print custom sized labels up to one metre in length using the built-in cutter and continuous rolls, you can see why this is the most advanced label printer available.
Key Features
- USB, Ethernet, Wi-Fi and Bluetooth connectivity with support for MFi and AirPrint
- Print on pre sized labels (for your address shipping labels) or continuous rolls up to 62mm wide (for indoor/outdoor signage). Or print labels stored in memory using the integrated control panel.
- Large backlit LCD display for easy set-up and operation
- Print in black and red without needing ink or toner
- Built-in cutter to create your own length labels
- Optional rechargeable Li-ion battery base for mobile labelling applications
- Brother QL-820NWB - label printer - two-colour (monochrome) - direct thermal
- Printer Type
- Label printer - direct thermal - two-colour (monochrome)
- 1.16 kg
- Localisation
- Ireland
- Max Media Size
- Roll (6.2 cm)
- Max Media Size (Custom)
- 62 mm
- Print Speed
- Up to 110 labels/min , Up to 176 mm/sec
- Max Resolution (B&W)
- 300 x 600 dpi
- Cutter
- Interface
- USB 2.0, LAN, Wi-Fi(n), USB host, Bluetooth 2.1 EDR
- AirPrint Enabled
- Barcodes
- Code 93, Code 39, GS1 DataBar, QR code, MaxiCode, UPC-A, UPC-E, MicroPDF417, Codabar, Code 128, Postnet, PDF417, Data Matrix, ITF, Micro QR code, EAN-8, EAN-13, GS1-128
- Media Type
- Die cut labels, label continuous paper
- Compatible Tapes
- DK tape
- Fonts
- Brussels, Helsinki, Letter Gothic
- Styles & Effects
- Bold, normal, vertical, shadow, italic, shadow light, surround, horizontal lines, invert
- Printer Features
- Auto Power Off
- Battery
- Required 1 Lithium Ion Included Qty 0
- System Requirements
- Linux, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2012, Windows 8 (32/64 bits), Microsoft Windows Server 2012 R2, Apple MacOS X 10.10.x, Windows 10 (32/64 bits), Apple MacOS X 10.11.x, Apple macOS 10.12.x
- Enclosure Colour
- White, glossy black
- 1-year warranty
- 12.53 cm x 23.4 cm x 14.5 cm
- Printer Type
- Enclosure Colour
- Localisation
- Ireland
Printer
- Print Speed
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wireless
- Interface
- AirPrint Enabled
- 300 x 600 dpi
- Fonts
- Styles & Effects
- Auto Cutter
- Barcodes
- Printer Features
- Auto Power Off
Media Handling
- Media Type
- Compatible Tapes
- DK tape
- Max Media Size
- Roll (6.2 cm)
- 62 mm
- Media Sizes
- Roll (6.2 cm)
- Max Printing Width
- 58 mm
- Media Feeders
- 1 x manual - 1 roll - Roll (6.2 cm)
- Connections
- 1 x USB 2.0 , 1 x LAN - RJ-45 , 1 x USB host - 4 pin USB Type A
- Cables Included
- 1 x USB cable
- Media Included
- 62 mm x 5 m black/red paper tape, 29 x 90 mm black on white standart address labels (100 labels)
- MFI
- Power Device
- Power adapter - external
- Frequency Required
- 50/60 Hz
- Lithium Ion
- Required Qty
- 1
- Included
- 0
- Software Included
- Software Development Kit (SDK)
- OS Required
- Limited warranty - 1 year
- 10 °C
- 35 °C
- 20 - 80%
- 12.53 cm
- 23.4 cm
- 14.5 cm
- 1.16 kg
Ink (7)
Brother Large Address Labels | In Stock | £7.98 |
Brother DK Continuous White Labels | In Stock | £13.36 |
Brother Shipping 62 x 100mm 300 Labels | In Stock | £11.50 |
Brother P-TOUCH Yellow Paper- 62mm | In Stock | £13.31 |
Brother p-touch White Paper - 62mm | In Stock | £12.13 |
Brother Paper Roll (6.2 cm x 30.5 m) | In Stock | £10.46 |
Brother Non Adhesive Paper Tape 54mm | In Stock | £11.43 |
Other bundles (2)
Brother BROTHER DK-22212 TAPE 62MM WH. | In Stock | £34.43 |
Brother P-TOUCH TAPE PAPER 29MMX30.48M | In Stock | £6.27 |
