The QL-720NW offers your workgroup the convenient flexibility of being able to print via either wired or wireless networking.
This versatile machine will print up to 93 labels a minute at up to 600dpi, and comes complete with all the software needed to quickly and simply integrate it with your current networks and business systems.
And you can even print directly from MS Word, Excel and Outlook, as well as from your mobile device thanks to Brother's free iPrint & Label app.
- Brother QL-720NW - label printer - B/W - direct thermal
- Printer Type
- Label printer - direct thermal - B/W
- 1.2 kg
- Max Media Size
- Roll (6.2 cm)
- Max Media Size (Custom)
- 62 mm
- Print Speed
- Up to 93 labels/min , Up to 150 mm/sec
- Max Resolution (B&W)
- 300 x 720 dpi
- Cutter
- Interface
- USB, LAN, serial, Wi-Fi(n)
- Barcodes
- Code 39, UCC/EAN-128, ISBN, GS1 DataBar, QR code, MaxiCode, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Codabar, Code 128, Postnet, PDF417, Data Matrix, ITF
- Media Type
- Envelopes, labels, address labels, file folder labels, CD/DVD labels, shipping labels, die cut labels
- Compatible Tapes
- DK tape
- Styles & Effects
- Vertical, Mirror, rotated text
- Networking
- Print server - Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- System Requirements
- Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Microsoft Windows XP SP3 or later, Microsoft Windows Server 2008, Apple MacOS X 10.5.8 - 10.7
- 3-year warranty
- 12.8 cm x 23.6 cm x 15.3 cm
- Printer Type
- Label printer - direct thermal - monochrome
Printer
- Print Speed
- Connectivity Technology
- Wireless
- Interface
- 300 x 720 dpi
- Styles & Effects
- Auto Cutter
- Repeating Printing
- 9999 copies
- Barcodes
Media Handling
- Media Type
- Compatible Tapes
- DK tape
- Max Media Size
- Roll (6.2 cm)
- 62 mm
- Media Sizes
- Roll (6.2 cm)
- Max Printing Width
- 58.4 mm
- Max Printing Length
- 914 mm
- Media Feeders
- 1 x manual - 1 roll - Roll (6.2 cm)
- Networking
- Print server
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Connections
- 1 x LAN - RJ-45 , 1 x RS-232 - 9 pin D-Sub (DB-9) , 1 x USB - 4 pin USB Type B
- Cables Included
- 1 x USB cable
- Media Included
- 1 62 mm x 8 m label tape cassette, 1 roll of 100 address labels
- Power Device
- Power supply - internal
- Software Included
- Drivers & Utilities, P-touch Address Book 1.1 for Windows, P-touch Editor 5.0 for Mac OS, P-touch Editor 5.0 for Windows
- OS Required
- Limited warranty - 3 years - carry-in
- 12.8 cm
- 23.6 cm
- 15.3 cm
- 1.2 kg
