Brother QL 700 Thermal Label Printer
Quicklinx: 7YFHWS00 Mfr#: QL700SZU1
Type: Printer
Functionality: Printer
Output Type: Monochrome
Wireless Capability: Wired
Technology: Direct thermal
Hurry, only 1 left in stock!
£63.56 ex VAT
£76.27 inc VAT
Professional, high-speed label printer helps you quickly tackle labeling tasks in your busy office. Create cost-effective paper labels for file folders, envelopes, packages, and DVDs - even create banners and signs up to 3 feet long. The ultra-fast print speeds of up to 93 labels per minute help save time on big projects. Whether you print 1 label or multiple labels at a time, the convenient, automatic cutter speeds your job along.
Use one of the two easy ways to create labels... Press the editor lite button to launch the intuitive, built-in plug and label software to quickly type and print labels without installing software. Or install the included P-touch editor label design software to create more elaborate labels. Plus, print postage and save trips to the post office. Print the exact postage you need, when you need it right from your desktop.
Brother QL-700 - label printer - B/W - direct thermal
Printer Type
Label printer - direct thermal - B/W
1.12 kg
Max Media Size
Roll (6.2 cm)
Print Speed
Up to 150 mm/sec , Up to 93 labels/min
Max Resolution (B&W)
300 x 600 dpi
Cutter
USB
Barcodes
Code 39, UCC/EAN-128, QR code, MaxiCode, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Codabar, Code 128, PDF417, Data Matrix, ITF, GS1 DataBar Omnidirectional, GS1 DataBar Stacked
Media Type
Continuous paper labels, die cut labels
Compatible Tapes
DK tape
Styles & Effects
Vertical, Mirror
12.8 cm x 22.1 cm x 15.3 cm
Printer Type
Label printer - direct thermal - monochrome
Printer
Print Speed
Wired
USB
300 x 600 dpi
Styles & Effects
Vertical, Mirror
Auto Cutter
Repeating Printing
9999 copies
Barcodes
Media Handling
Media Type
Compatible Tapes
DK tape
Max Media Size
Roll (6.2 cm)
Media Sizes
Roll (6.2 cm)
Max Printing Width
59 mm
1 x USB - 4 pin USB Type B
1 x USB cable
Media Included
1 62 mm x 8 m label tape cassette, 1 roll of 100 address labels
Software Included
Brother P-touch Editor
12.8 cm
22.1 cm
15.3 cm
1.12 kg
Ink (7)
7YFH Brother Large Address Labels In Stock £7.97
7YFH Brother DK Continuous White Labels In Stock £14.22
7YFH Brother Shipping 62 x 100mm 300 Labels In Stock £11.52
7YFH Brother P-TOUCH Yellow Paper- 62mm In Stock £14.11
7YFH Brother p-touch White Paper - 62mm In Stock £12.88
7YFH Brother Paper Roll (6.2 cm x 30.5 m) In Stock £10.48
7YFH Brother Non Adhesive Paper Tape 54mm In Stock £11.50
Other bundles (2)
7YFH Brother BROTHER DK-22212 TAPE 62MM WH. In Stock £34.26
7YFH Brother P-TOUCH TAPE PAPER 29MMX30.48M In Stock £6.71
Type: Printer
Max Print Speed: [N/A]
Max Paper Size: Roll (6.2 cm)
Brand: Brother
