Professional, high-speed label printer helps you quickly tackle labeling tasks in your busy office. Create cost-effective paper labels for file folders, envelopes, packages, and DVDs - even create banners and signs up to 3 feet long. The ultra-fast print speeds of up to 93 labels per minute help save time on big projects. Whether you print 1 label or multiple labels at a time, the convenient, automatic cutter speeds your job along.
Use one of the two easy ways to create labels... Press the editor lite button to launch the intuitive, built-in plug and label software to quickly type and print labels without installing software. Or install the included P-touch editor label design software to create more elaborate labels. Plus, print postage and save trips to the post office. Print the exact postage you need, when you need it right from your desktop.
- Brother QL-700 - label printer - B/W - direct thermal
- Printer Type
- Label printer - direct thermal - B/W
- 1.12 kg
- Max Media Size
- Roll (6.2 cm)
- Print Speed
- Up to 150 mm/sec , Up to 93 labels/min
- Max Resolution (B&W)
- 300 x 600 dpi
- Cutter
- Interface
- USB
- Barcodes
- Code 39, UCC/EAN-128, QR code, MaxiCode, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Codabar, Code 128, PDF417, Data Matrix, ITF, GS1 DataBar Omnidirectional, GS1 DataBar Stacked
- Media Type
- Continuous paper labels, die cut labels
- Compatible Tapes
- DK tape
- Styles & Effects
- Vertical, Mirror
- 12.8 cm x 22.1 cm x 15.3 cm
- Printer Type
- Label printer - direct thermal - monochrome
Printer
- Print Speed
- Connectivity Technology
- Wired
- Interface
- USB
- 300 x 600 dpi
- Styles & Effects
- Vertical, Mirror
- Auto Cutter
- Repeating Printing
- 9999 copies
- Barcodes
Media Handling
- Media Type
- Compatible Tapes
- DK tape
- Max Media Size
- Roll (6.2 cm)
- Media Sizes
- Roll (6.2 cm)
- Max Printing Width
- 59 mm
- Connections
- 1 x USB - 4 pin USB Type B
- Cables Included
- 1 x USB cable
- Media Included
- 1 62 mm x 8 m label tape cassette, 1 roll of 100 address labels
- Software Included
- Brother P-touch Editor
- 12.8 cm
- 22.1 cm
- 15.3 cm
- 1.12 kg
Ink (7)
Brother Large Address Labels | In Stock | £7.97 |
Brother DK Continuous White Labels | In Stock | £13.41 |
Brother Shipping 62 x 100mm 300 Labels | In Stock | £11.50 |
Brother P-TOUCH Yellow Paper- 62mm | In Stock | £13.31 |
Brother p-touch White Paper - 62mm | In Stock | £12.01 |
Brother Paper Roll (6.2 cm x 30.5 m) | In Stock | £10.44 |
Brother Non Adhesive Paper Tape 54mm | In Stock | £11.53 |
Other bundles (2)
Brother BROTHER DK-22212 TAPE 62MM WH. | In Stock | £34.24 |
Brother P-TOUCH TAPE PAPER 29MMX30.48M | In Stock | £6.27 |
