Brother QL-700 Die Cut & Continuous Label Printer - Auto Cutter
Quicklinx: 8VHGWS00 Mfr#: QL700ZU1
Type: Printer
Functionality: Printer
Output Type: Monochrome
Wireless Capability: Wired
Technology: Direct thermal
24 In Stock
£75.19 ex VAT
£90.22 inc VAT
Offering versatility, convenience and Microsoft integration, the QL-700 delivers totally hassle-free address label printing.
'P-Touch Editor Lite' is pre-loaded to the printer itself so there's no software installation required for PC or Mac.  And it's fast, producing up to 93 labels a minute at up to 600dpi, with an automatic label cutter built in for ultimate convenience. You can also print directly from MS Word, Excel and Outlook too.
With the QL-700, your envelopes and packages can carry clear, professional-looking labels – you can even add your company logo if you'd like.
Brother QL-700 - label printer - B/W - direct thermal
Printer Type
Label printer - direct thermal - B/W
1.12 kg
Max Media Size
Roll (6.2 cm)
Min Media Size (Custom)
12.7 mm
Max Media Size (Custom)
62 mm x 1000 mm
Print Speed
Up to 150 mm/sec , Up to 93 labels/min
Max Resolution (B&W)
300 x 600 dpi
Cutter
USB
Barcodes
Code 39, UCC/EAN-128, QR code, MaxiCode, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Codabar, Code 128, PDF417, Data Matrix, ITF, GS1 DataBar Omnidirectional, GS1 DataBar Stacked
Media Type
Continuous paper labels, die cut labels
Compatible Tapes
DK tape
Styles & Effects
Vertical, Mirror
Microsoft Windows Vista / XP / 7, Apple MacOS X 10.4.11 - 10.7
3-year warranty
12.8 cm x 22.1 cm x 15.3 cm
Printer Type
Label printer - direct thermal - monochrome
Printer
Print Speed
Wired
USB
300 x 600 dpi
Styles & Effects
Vertical, Mirror
Auto Cutter
Repeating Printing
9999 copies
Barcodes
Media Handling
Media Type
Compatible Tapes
DK tape
Max Media Size
Roll (6.2 cm)
12.7 mm
62 mm x 1000 mm
Media Sizes
Roll (6.2 cm)
Max Printing Width
59 mm
1 x USB - 4 pin USB Type B
1 x USB cable
Media Included
1 62 mm x 8 m label tape cassette, 1 roll of 100 address labels
Software Included
Brother P-touch Editor
Limited warranty - 3 years
12.8 cm
22.1 cm
15.3 cm
1.12 kg
Ink (7)
8VHG Brother Large Address Labels In Stock £7.82
8VHG Brother DK Continuous White Labels In Stock £13.76
8VHG Brother Shipping 62 x 100mm 300 Labels In Stock £13.68
8VHG Brother P-TOUCH Yellow Paper- 62mm In Stock £13.67
8VHG Brother p-touch White Paper - 62mm In Stock £12.46
8VHG Brother Paper Roll (6.2 cm x 30.5 m) In Stock £10.79
8VHG Brother Non Adhesive Paper Tape 54mm In Stock £11.83
Other bundles (1)
8VHG Brother BROTHER DK-22212 TAPE 62MM WH. In Stock £35.39
Type: Printer
Max Print Speed: [N/A]
Max Paper Size: Roll (6.2 cm)
Brand: Brother
