Offering versatility, convenience and Microsoft integration, the QL-700 delivers totally hassle-free address label printing.
'P-Touch Editor Lite' is pre-loaded to the printer itself so there's no software installation required for PC or Mac. And it's fast, producing up to 93 labels a minute at up to 600dpi, with an automatic label cutter built in for ultimate convenience. You can also print directly from MS Word, Excel and Outlook too.
With the QL-700, your envelopes and packages can carry clear, professional-looking labels – you can even add your company logo if you'd like.
- Brother QL-700 - label printer - B/W - direct thermal
- Printer Type
- Label printer - direct thermal - B/W
- 1.12 kg
- Max Media Size
- Roll (6.2 cm)
- Min Media Size (Custom)
- 12.7 mm
- Max Media Size (Custom)
- 62 mm x 1000 mm
- Print Speed
- Up to 150 mm/sec , Up to 93 labels/min
- Max Resolution (B&W)
- 300 x 600 dpi
- Cutter
- Interface
- USB
- Barcodes
- Code 39, UCC/EAN-128, QR code, MaxiCode, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Codabar, Code 128, PDF417, Data Matrix, ITF, GS1 DataBar Omnidirectional, GS1 DataBar Stacked
- Media Type
- Continuous paper labels, die cut labels
- Compatible Tapes
- DK tape
- Styles & Effects
- Vertical, Mirror
- System Requirements
- Microsoft Windows Vista / XP / 7, Apple MacOS X 10.4.11 - 10.7
- 3-year warranty
- 12.8 cm x 22.1 cm x 15.3 cm
- Printer Type
- Label printer - direct thermal - monochrome
Printer
- Print Speed
- Connectivity Technology
- Wired
- Interface
- USB
- 300 x 600 dpi
- Styles & Effects
- Vertical, Mirror
- Auto Cutter
- Repeating Printing
- 9999 copies
- Barcodes
Media Handling
- Media Type
- Compatible Tapes
- DK tape
- Max Media Size
- Roll (6.2 cm)
- 12.7 mm
- 62 mm x 1000 mm
- Media Sizes
- Roll (6.2 cm)
- Max Printing Width
- 59 mm
- Connections
- 1 x USB - 4 pin USB Type B
- Cables Included
- 1 x USB cable
- Media Included
- 1 62 mm x 8 m label tape cassette, 1 roll of 100 address labels
- Software Included
- Brother P-touch Editor
- OS Required
- Limited warranty - 3 years
- 12.8 cm
- 22.1 cm
- 15.3 cm
- 1.12 kg
Ink (7)
Brother Large Address Labels | In Stock | £7.82 |
Brother DK Continuous White Labels | In Stock | £13.76 |
Brother Shipping 62 x 100mm 300 Labels | In Stock | £13.60 |
Brother P-TOUCH Yellow Paper- 62mm | In Stock | £13.67 |
Brother p-touch White Paper - 62mm | In Stock | £12.46 |
Brother Paper Roll (6.2 cm x 30.5 m) | In Stock | £10.79 |
Brother Non Adhesive Paper Tape 54mm | In Stock | £11.83 |
Other bundles (1)
Brother BROTHER DK-22212 TAPE 62MM WH. | In Stock | £35.39 |
