Brother QL-600B Postage and Address Label Printer
Quicklinx: HX0QWS00 Mfr#: QL600BZU1
Type: Printer
Functionality: Printer
Wireless Capability: Wired
Max Paper Size: Roll (6.2 cm)
13 In Stock
£52.92 ex VAT
£63.50 inc VAT
The smart, compact design of the QL-600B address label printer allows it to sit neatly on your desk, connected to your PC or Mac's USB interface. Using P-touch Editor label design software (available as a free download) you can add text, images, barcodes, frames and other items onto your labels before printing.
Use the integrated cutter together with one of the continuous DK label rolls to create labels up to one meter in length - ideal for signs and banners.
Or add to this a large range of various pre-sized die-cut label rolls, and you have the ideal postage or shipping label printer that can do so much more.
  • Efficient barcode printing
    Supports a wide range of barcodes including Aztec code, Codabar, Code 128, and QR code, making it versatile for various labeling needs.
  • High-quality output
    Utilizes direct thermal printing technology to produce monochrome labels with a maximum resolution of 300 x 300 DPI, ensuring clear and legible prints.
  • Flexible media handling
    Accommodates rolls up to 6.2 cm wide and labels from 12.7 mm to 1000 mm long, including continuous labels, die cut labels, and more, offering a range of labeling options.
  • Fast printing speed
    Achieves a maximum printing speed of 71 mm/s, enabling quick creation of labels to improve productivity.
  • Easy connectivity
    Features USB 2.0 interface for simple and reliable connection to computers, enhancing user experience and setup ease.
Brother QL-600B - label printer - B/W - direct thermal
Printer Type
Label printer - direct thermal - B/W
1.12 kg
Max Media Size
Roll (6.2 cm)
Min Media Size (Custom)
12.7 mm
Max Media Size (Custom)
62 mm
Print Speed
Up to 71 mm/sec
Max Resolution (B&W)
300 x 300 dpi
USB 2.0
Barcodes
Code 39, UCC/EAN-128, GS1 DataBar, QR code, MaxiCode, Aztec code, UPC-A, UPC-E, Codabar, Code 128, Postnet, PDF417, Data Matrix, Intelligent Mail Barcode, ITF 2 of 5, EAN-8, EAN-13, MSI, ISBN-2, ISBN-5, RSS
Media Type
Labels, continuous labels, die cut labels
Compatible Tapes
DK tape
Enclosure Colour
Blue-white
12.8 cm x 22.1 cm x 15.3 cm
Printer Type
Label printer - direct thermal - monochrome
Enclosure Colour
Blue-white
Printer
Print Speed
Up to 71 mm/sec
Wired
USB 2.0
300 x 300 dpi
Barcodes
Media Handling
Media Type
Compatible Tapes
DK tape
Max Media Size
Roll (6.2 cm)
12.7 mm
62 mm
Media Sizes
Roll (6.2 cm)
Max Printing Width
60.96 mm
Max Printing Length
1000 mm
Media Feeders
1 x manual - Roll (6.2 cm)
1 x USB 2.0 - 4 pin USB Type B
1 x USB cable
Media Included
62 mm x 8 m continuous length paper tape
Power supply - internal
Software Included
Brother P-touch Editor
12.8 cm
22.1 cm
15.3 cm
1.12 kg
Ink (2)
HX0Q Brother DK Continuous White Labels In Stock £13.30
HX0Q Brother Paper Roll (6.2 cm x 30.5 m) In Stock £10.44
Other bundles (1)
HX0Q Brother BROTHER DK-22212 TAPE 62MM WH. In Stock £34.24
Type: Printer
Brand: Brother
