The smart, compact design of the QL-600B address label printer allows it to sit neatly on your desk, connected to your PC or Mac's USB interface. Using P-touch Editor label design software (available as a free download) you can add text, images, barcodes, frames and other items onto your labels before printing.
Use the integrated cutter together with one of the continuous DK label rolls to create labels up to one meter in length - ideal for signs and banners.
Or add to this a large range of various pre-sized die-cut label rolls, and you have the ideal postage or shipping label printer that can do so much more.
Efficient barcode printing
Supports a wide range of barcodes including Aztec code, Codabar, Code 128, and QR code, making it versatile for various labeling needs. -
High-quality output
Utilizes direct thermal printing technology to produce monochrome labels with a maximum resolution of 300 x 300 DPI, ensuring clear and legible prints. -
Flexible media handling
Accommodates rolls up to 6.2 cm wide and labels from 12.7 mm to 1000 mm long, including continuous labels, die cut labels, and more, offering a range of labeling options. -
Fast printing speed
Achieves a maximum printing speed of 71 mm/s, enabling quick creation of labels to improve productivity. -
Easy connectivity
Features USB 2.0 interface for simple and reliable connection to computers, enhancing user experience and setup ease.
- Brother QL-600B - label printer - B/W - direct thermal
- Printer Type
- Label printer - direct thermal - B/W
- 1.12 kg
- Max Media Size
- Roll (6.2 cm)
- Min Media Size (Custom)
- 12.7 mm
- Max Media Size (Custom)
- 62 mm
- Print Speed
- Up to 71 mm/sec
- Max Resolution (B&W)
- 300 x 300 dpi
- Interface
- USB 2.0
- Barcodes
- Code 39, UCC/EAN-128, GS1 DataBar, QR code, MaxiCode, Aztec code, UPC-A, UPC-E, Codabar, Code 128, Postnet, PDF417, Data Matrix, Intelligent Mail Barcode, ITF 2 of 5, EAN-8, EAN-13, MSI, ISBN-2, ISBN-5, RSS
- Media Type
- Labels, continuous labels, die cut labels
- Compatible Tapes
- DK tape
- Enclosure Colour
- Blue-white
- 12.8 cm x 22.1 cm x 15.3 cm
- Printer Type
- Label printer - direct thermal - monochrome
- Enclosure Colour
- Blue-white
Printer
- Print Speed
- Up to 71 mm/sec
- Connectivity Technology
- Wired
- Interface
- USB 2.0
- 300 x 300 dpi
- Barcodes
Media Handling
- Media Type
- Compatible Tapes
- DK tape
- Max Media Size
- Roll (6.2 cm)
- 12.7 mm
- 62 mm
- Media Sizes
- Roll (6.2 cm)
- Max Printing Width
- 60.96 mm
- Max Printing Length
- 1000 mm
- Media Feeders
- 1 x manual - Roll (6.2 cm)
- Connections
- 1 x USB 2.0 - 4 pin USB Type B
- Cables Included
- 1 x USB cable
- Media Included
- 62 mm x 8 m continuous length paper tape
- Power Device
- Power supply - internal
- Software Included
- Brother P-touch Editor
- 12.8 cm
- 22.1 cm
- 15.3 cm
- 1.12 kg
Ink (2)
Brother DK Continuous White Labels | In Stock | £13.82 |
Brother Paper Roll (6.2 cm x 30.5 m) | In Stock | £10.87 |
Other bundles (1)
Brother BROTHER DK-22212 TAPE 62MM WH. | In Stock | £35.57 |
