Brother QL 1060N Mono Direct Thermal Label Printer
Quicklinx: 74XYWS00 Mfr#: QL1060NZU1
The QL-1060N delivers the best of both worlds – proven, practical label printing with all the increased productivity benefits of wired network connectivity.
Print from any computer in your network to one centralised label printer, where the up to 300dpi print resolution reproduces logos and barcodes perfectly in sizes from 12mm to a massive 102mm wide. And with printing speeds of up to 69 labels per minute and a built-in heavy-duty automatic cutter, high volumes are no problem.
Offering consistent, professional labelling, the QL-1060N makes all the right business connections.
Brother QL-1060N - label printer - monochrome - direct thermal
Printer Type
Label printer - direct thermal - monochrome
1.7 kg
Max Media Size
Roll (10.2cm)
Min Media Size (Custom)
12 mm
Max Media Size (Custom)
102 mm
Print Speed
Up to 110 mm/sec , Up to 69 labels/min
Max Resolution (B&W)
300 dpi
USB, LAN, serial
RAM Installed (Max)
4 MB
Language Simulation
EPSON ESC/P, EPSON ESC/P Raster
Barcodes
Code 39, UCC/EAN-128, GS1 DataBar, QR code, MaxiCode, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Codabar, Code 128, PDF417, Data Matrix, ITF
Media Type
Labels, continuous forms, removable labels
Compatible Tapes
DK tape
Fonts
Brussels, Helsinki, San Diego, Letter Gothic, Letter Gothic Bold
Character Sizes
24 points, 48 points, 32 points
Styles & Effects
Bold, outline shadow, solid, vertical, outline, shadow, italic, underline
Print server - Ethernet, Fast Ethernet - external
AC 230V
Microsoft Windows 2000 Professional, Microsoft Windows XP, Microsoft Windows Server 2003, Microsoft Windows Vista, Apple MacOS X 10.3.9 - 10.4.10
Microsoft Certification
Works with Windows Vista
3-year warranty
17 cm x 22 cm x 14.8 cm
Printer Type
Printer
Print Speed
Built-in Devices
Cutter
Wired
USB, LAN, serial
300 dpi
Language Simulation
Fonts
Character Sizes
Styles & Effects
Auto Cutter
Barcodes
RAM
RAM Installed (Max)
4 MB
Media Handling
Media Type
Compatible Tapes
DK tape
Max Media Size
Roll (10.2cm)
12 mm
102 mm
Media Sizes
Roll (1.2 cm), Roll (10.2cm), Roll (6.2 cm)
Max Printing Width
98.6 mm
Print server - external
1 x USB - 4 pin USB Type B , 1 x RS-232 - 9 pin D-Sub (DB-9) , 1 x LAN - RJ-45
1 x USB cable
Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
Power supply - internal
AC 230V
Software Included
Drivers & Utilities, Brother P-touch Quick Editor, Brother P-touch Editor V4.0
Additional Requirements
CD-ROM
System Requirements Details
MacOS X 10.3.9 - 10.4.10 - PowerPC HD 100 MB , Windows 2000 Pro - HD 70 MB , Windows XP - HD 70 MB , Windows Vista - HD 70 MB , Windows Server 2003 - HD 70 MB
Limited warranty - 3 years - carry-in
17 cm
22 cm
14.8 cm
1.7 kg
