Brother PTD450VP 18mm Desktop Label Printer
Quicklinx: B1J8WS00 Mfr#: PTD450VPZU1
From file dividers to cabinets, office equipment to name badges, having everything clearly labelled is a sure-fire way to get your workplace organised and running smoothly.
With the PT-D450VP, you can quickly generate labels up to 18mm wide, either using the printer's own PC-style 'QWERTY' keyboard and high resolution backlit display to create them direct or sending your designs via your PC. It also comes complete with its own handy carry case, 18mm black on white label tape and adapter.
  • PC-connectable
    Use stand-alone, or connected to a PC or Mac for added design capabilities.
  • Split-back tapes
    Uses durable, easy-peel tapes in 4 different widths up to 18mm (approx. ¾").
  • One-touch keys
    Easily add frames and other formatting features.
  • Large memory
    Save up to 50 commonly used labels and help save time with reprinting.
  • Specialty templates
    Print labels for asset management, cable labeling and more.
Brother P-Touch PT-D450VP - labelmaker - B/W - thermal transfer
Printer Type
Labelmaker - thermal transfer - B/W
740 g
Max Media Size
Roll (1.8 cm)
Max Media Size (Custom)
18 mm
Print Speed
Up to 20 mm/sec
Cutter
USB
Media Type
Laminated tape
Compatible Tapes
TZe tape
Fonts
14 fonts
Styles & Effects
Vertical, underline
5 line printing
Display Resolution
320 x 120
Keyboard
QWERTY / 65 keys
Microsoft Windows 7, Microsoft Windows Vista, Windows 8, Apple MacOS X 10.8.x, Windows 8.1, Apple MacOS X 10.7.5, Apple MacOS X 10.9.x
Enclosure Colour
18.8 cm x 17.7 cm x 7.2 cm
Printer Type
Labelmaker - thermal transfer - monochrome
Enclosure Colour
Printer
Print Speed
Up to 20 mm/sec
Built-in Devices
Preview screen, character keyboard
USB
Fonts
14 fonts
Styles & Effects
Vertical, underline
5 line printing
Display Resolution
320 x 120
Auto Cutter
Keyboard
QWERTY / 65 keys
Repeating Printing
5000 copies
Media Handling
Media Type
Laminated tape
Compatible Tapes
TZe tape
Max Media Size
Roll (1.8 cm)
18 mm
Media Sizes
Roll (0.6 cm), Roll (1.8 cm), Roll (1.2 cm), Roll (0.9 cm), Roll (0.35 cm)
Max Printing Width
15.8 mm
Media Feeders
1 x manual - 1 roll - Roll (1.8 cm)
1 x USB
Carrying case
1 x USB cable
Media Included
1 18 mm x 4 m black on white TZe laminated tape cassette
Power adapter
System Requirements Details
Windows Vista/7/8/8.1 - RAM 512 MB - HD 70 MB , MacOS - RAM 2 GB - HD 500 MB
10 °C
35 °C
20 - 80% (non-condensing)
18.8 cm
17.7 cm
7.2 cm
740 g
Ink (16)
B1J8 Brother TZES221 Black on White 9mm In Stock £10.44
B1J8 Brother TZe-S211 - laminated tape - 1 cassette(s) - Roll (0.6 cm x 8 m) In Stock £9.59
B1J8 Brother TZE-651 24MM BLACK ON YELLOW In Stock £16.80
B1J8 Brother TZe-241 - laminated tape - 1 cassette(s) - Roll (1.8 cm x 8 m) In Stock £11.23
B1J8 Brother Laminated Tape 12mm Blk on Yel In Stock £9.38
B1J8 Brother Tape Black on Yellow 6mm In Stock £7.52
B1J8 Brother TZE-335 LAMINATED TAPE 12MM 8M In Stock £11.20
B1J8 Brother Tape Black on Yellow 12mm In Stock £11.47
B1J8 Brother Black On Clear Labelling Tape 12mm In Stock £8.48
B1J8 Brother 12mm Black on White Tape In Stock £11.49
B1J8 Brother Tape Black on Clear 9mm In Stock £7.58
B1J8 Brother 12mm Matt Black on Red Laminated Tape In Stock £9.93
B1J8 Brother 12mm Blue on White Tape In Stock £9.93
B1J8 Brother P-touch TZe-211 (6mm x 8m) Black On White Label Tape In Stock £7.81
B1J8 Brother BRO 24MM GLOSS TZ BLACK ON RED TAPE In Stock £16.80
B1J8 Brother TZEFX-231 Black On White Flexi Tape In Stock £11.49
Other bundles (1)
B1J8 Brother TZe 231 - laminated adhesive tape - 1 roll(s) In Stock £9.38
