The PT-P900W is a complete wireless on-demand laminating label printing solution that comes with printer, accessories, label design and print software, and a full length UL certified tape - all this for the price of just the printer! This small footprint printer produces wide, premium quality laminated labels at 360 dpi print resolution, up to 32 mm print height on 36 mm tape, and features a built-in automatic cutter that trims a continuous "tape" to virtually any length, one at a time or as a strip of pre-cut labels. Brother laminated labels can withstand abrasion, fading, extreme temperatures, chemicals and moisture.
- Create durable labels up to 36mm in width
- High speed and high resolution printing
- Integrated Wi-Fi to print labels from several devices at once, including tablets and smartphones
- Advanced cutter with easy label peel function
- Include images, barcodes and frames on your labels
- Connect to data contained in spreadsheets to batch print many labels at once
- Brother P-Touch PT-P900W - label printer - B/W - thermal transfer
- Printer Type
- Label printer - thermal transfer - B/W
- 1.48 kg
- Max Media Size
- Roll (3.6cm)
- Max Media Size (Custom)
- 36 mm
- Print Speed
- Up to 60 mm/sec
- Max Resolution (B&W)
- 360 x 720 dpi
- Cutter
- Interface
- USB 2.0, Wi-Fi(n)
- Language Simulation
- EPSON ESC/P
- Media Type
- Laminated tape
- Compatible Tapes
- TZe tape, HSe tape, FLe label
- Styles & Effects
- Normal, vertical, shadow, italic, shadow light, invert
- System Requirements
- Linux, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2012, Windows 8 (32/64 bits), Apple MacOS X 10.8.x, Microsoft Windows Server 2012 R2, Windows 8.1, Apple MacOS X 10.7.5, Apple MacOS X 10.9.x, Apple MacOS X 10.10.x, Windows 10 (32/64 bits), Apple MacOS X 10.11.x
- 11.8 cm x 19.2 cm x 14.6 cm
- Printer Type
- Label printer - thermal transfer - monochrome
Printer
- Print Speed
- Up to 60 mm/sec
- Interface
- USB 2.0, Wi-Fi(n)
- 360 x 720 dpi
- EPSON ESC/P
- Styles & Effects
- Auto Cutter
- Repeating Printing
- 5000 copies
Media Handling
- Media Type
- Laminated tape
- Compatible Tapes
- Max Media Size
- Roll (3.6cm)
- 36 mm
- Media Sizes
- Roll (2.4 cm), Roll (0.6 cm), Roll (1.8 cm), Roll (1.2 cm), Roll (0.9 cm), Roll (3.6cm), Roll (0.35 cm), Roll (0.58 cm), Roll (2.36 cm), Roll (1.77 cm), Roll (1.17 cm), Roll (0.88 cm), 21 x 45 mm
- Media Feeders
- 1 x manual - 1 roll - Roll (3.6cm)
- Connections
- 1 x USB 2.0
- Cables Included
- 1 x USB cable
- Media Included
- 1 36 mm x 8 m black on white TZe tape
- Power Device
- Power adapter - external
- OS Required
- 10 °C
- 35 °C
- 20 - 80%
- 11.8 cm
- 19.2 cm
- 14.6 cm
- 1.48 kg
Ink (22)
Brother TZES221 Black on White 9mm | In Stock | £10.11 |
Brother TZe-S211 - laminated tape - 1 cassette(s) - Roll (0.6 cm x 8 m) | In Stock | £9.89 |
Brother TZE-651 24MM BLACK ON YELLOW | In Stock | £16.21 |
Brother TZe-241 - laminated tape - 1 cassette(s) - Roll (1.8 cm x 8 m) | In Stock | £10.77 |
Brother TZES651 24mm Black on Yellow | In Stock | £14.54 |
Brother Laminated Tape 12mm Blk on Yel | In Stock | £9.67 |
Brother Tape Black on Yellow 6mm | In Stock | £7.78 |
Brother TZE-335 LAMINATED TAPE 12MM 8M | In Stock | £11.59 |
Brother Tape Black on Yellow 12mm | In Stock | £11.86 |
Brother Black On Clear Labelling Tape 12mm | In Stock | £8.73 |
Brother 12mm Black on White Tape | In Stock | £11.86 |
Brother Tape Black on Clear 9mm | In Stock | £7.78 |
Brother 12mm Matt Black on Red Laminated Tape | In Stock | £10.24 |
Brother P-touch (36mm x 8m) Black On Blue Labelling Tape | In Stock | £17.31 |
Brother TZe 661 Laminated Tape - 1 Roll | In Stock | £16.06 |
Brother TZESE4 Black on White 18MM Security Tape | In Stock | £24.49 |
Brother 12mm Blue on White Tape | In Stock | £10.24 |
Brother TZeN241 Non-Laminated Tape - 1 roll | In Stock | £9.87 |
Brother P-touch TZe-211 (6mm x 8m) Black On White Label Tape | In Stock | £7.54 |
Brother TZE621 9MM GLOSS Black on Yellow Tape | In Stock | £8.73 |
Brother BRO 24MM GLOSS TZ BLACK ON RED TAPE | In Stock | £17.33 |
Brother TZEFX-231 Black On White Flexi Tape | In Stock | £11.86 |
Other bundles (1)
Brother TZe 231 - laminated adhesive tape - 1 roll(s) | In Stock | £9.61 |
