Brother PT-P900W Mono Label Printer
Quicklinx: CKPTWS00 Mfr#: PT-P900WZU1
  • Windows 8 (32/64 bits)
The PT-P900W is a complete wireless on-demand laminating label printing solution that comes with printer, accessories, label design and print software, and a full length UL certified tape - all this for the price of just the printer! This small footprint printer produces wide, premium quality laminated labels at 360 dpi print resolution, up to 32 mm print height on 36 mm tape, and features a built-in automatic cutter that trims a continuous "tape" to virtually any length, one at a time or as a strip of pre-cut labels. Brother laminated labels can withstand abrasion, fading, extreme temperatures, chemicals and moisture.
  • Create durable labels up to 36mm in width
  • High speed and high resolution printing
  • Integrated Wi-Fi to print labels from several devices at once, including tablets and smartphones
  • Advanced cutter with easy label peel function
  • Include images, barcodes and frames on your labels
  • Connect to data contained in spreadsheets to batch print many labels at once
Brother P-Touch PT-P900W - label printer - B/W - thermal transfer
Printer Type
Label printer - thermal transfer - B/W
1.48 kg
Max Media Size
Roll (3.6cm)
Max Media Size (Custom)
36 mm
Print Speed
Up to 60 mm/sec
Max Resolution (B&W)
360 x 720 dpi
Cutter
USB 2.0, Wi-Fi(n)
Language Simulation
EPSON ESC/P
Media Type
Laminated tape
Compatible Tapes
TZe tape, HSe tape, FLe label
Styles & Effects
Normal, vertical, shadow, italic, shadow light, invert
Linux, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2012, Windows 8 (32/64 bits), Apple MacOS X 10.8.x, Microsoft Windows Server 2012 R2, Windows 8.1, Apple MacOS X 10.7.5, Apple MacOS X 10.9.x, Apple MacOS X 10.10.x, Windows 10 (32/64 bits), Apple MacOS X 10.11.x
11.8 cm x 19.2 cm x 14.6 cm
Printer Type
Label printer - thermal transfer - monochrome
Printer
Print Speed
Up to 60 mm/sec
USB 2.0, Wi-Fi(n)
360 x 720 dpi
Language Simulation
EPSON ESC/P
Styles & Effects
Auto Cutter
Repeating Printing
5000 copies
Media Handling
Media Type
Laminated tape
Compatible Tapes
Max Media Size
Roll (3.6cm)
36 mm
Media Sizes
Roll (2.4 cm), Roll (0.6 cm), Roll (1.8 cm), Roll (1.2 cm), Roll (0.9 cm), Roll (3.6cm), Roll (0.35 cm), Roll (0.58 cm), Roll (2.36 cm), Roll (1.77 cm), Roll (1.17 cm), Roll (0.88 cm), 21 x 45 mm
Media Feeders
1 x manual - 1 roll - Roll (3.6cm)
1 x USB 2.0
1 x USB cable
Media Included
1 36 mm x 8 m black on white TZe tape
Power adapter - external
10 °C
35 °C
20 - 80%
11.8 cm
19.2 cm
14.6 cm
1.48 kg
Ink (20)
CKPT Brother TZES221 Black on White 9mm In Stock £10.44
CKPT Brother TZe-S211 - laminated tape - 1 cassette(s) - Roll (0.6 cm x 8 m) In Stock £9.59
CKPT Brother TZE-651 24MM BLACK ON YELLOW In Stock £16.80
CKPT Brother TZe-241 - laminated tape - 1 cassette(s) - Roll (1.8 cm x 8 m) In Stock £11.23
CKPT Brother TZES651 24mm Black on Yellow In Stock £15.22
CKPT Brother Laminated Tape 12mm Blk on Yel In Stock £9.38
CKPT Brother Tape Black on Yellow 6mm In Stock £7.52
CKPT Brother TZE-335 LAMINATED TAPE 12MM 8M In Stock £11.20
CKPT Brother Tape Black on Yellow 12mm In Stock £11.47
CKPT Brother Black On Clear Labelling Tape 12mm In Stock £8.48
CKPT Brother 12mm Black on White Tape In Stock £11.49
CKPT Brother Tape Black on Clear 9mm In Stock £7.58
CKPT Brother 12mm Matt Black on Red Laminated Tape In Stock £9.93
CKPT Brother P-touch (36mm x 8m) Black On Blue Labelling Tape In Stock £16.73
CKPT Brother TZe 661 Laminated Tape - 1 Roll In Stock £16.88
CKPT Brother 12mm Blue on White Tape In Stock £9.93
CKPT Brother P-touch TZe-211 (6mm x 8m) Black On White Label Tape In Stock £7.81
CKPT Brother TZE621 9MM GLOSS Black on Yellow Tape In Stock £8.48
CKPT Brother BRO 24MM GLOSS TZ BLACK ON RED TAPE In Stock £16.80
CKPT Brother TZEFX-231 Black On White Flexi Tape In Stock £11.49
Other bundles (1)
CKPT Brother TZe 231 - laminated adhesive tape - 1 roll(s) In Stock £9.38
