Brother PT-P300BTRE Label Machine
Quicklinx: HWZSWS00 Mfr#: PTP300BTRE1
Type: Printer
Functionality: Printer
Max Paper Size: Roll (1.2 cm)
£42.79 ex VAT
£51.34 inc VAT
The Brother P-Touch PT-P300BT is the Bluetooth label printer that works with your smartphone or tablet via P-Touch Design&Print app that comes with print-ready templates and frames.
  • Organize your home
    Try out the useful templates with pre-made labels and pattern designs. From labeling file folders, cables and wires, to making gift tags and scrapbook pages, there are more uses than ever for the PT-P300BT.
  • Print anywhere, anytime
    Use the Design&Print app and design labels from your smartphone.
  • Compact and portable design
    Built to fit into any home or office environment. It's lighter and smaller than any other similar products in the market today.
  • High speed printing
    The fast thermal label printer in its class with high print speed.
  • Expand your creativity with a great range of tapes
    With a great range of different tapes to choose from the possibilities are endless. Create stylish ribbon, decorative and laminated durable tapes that will add extra flair to your home or office.
Brother P-Touch PT-P300BT - label printer - B/W - thermal transfer
Printer Type
Label printer - thermal transfer - B/W
380 g
Max Media Size
Roll (1.2 cm)
Max Media Size (Custom)
12 mm
Print Speed
Up to 20 mm/sec
Max Resolution (B&W)
180 dpi
Cutter
Bluetooth 2.1 EDR
Media Type
Laminated tape
Compatible Tapes
TZe tape
Styles & Effects
Bold, vertical, italic, horizontal lines
Required 6 x AAA type Alkaline Included Qty 0
11.5 cm x 6.1 cm x 11.5 cm
Printer Type
Label printer - thermal transfer - monochrome
Printer
Print Speed
Up to 20 mm/sec
Bluetooth 2.1 EDR
180 dpi
Styles & Effects
Cutter
Media Handling
Media Type
Laminated tape
Compatible Tapes
TZe tape
Max Media Size
Roll (1.2 cm)
12 mm
Media Sizes
Roll (0.6 cm), Roll (1.2 cm), Roll (0.9 cm), Roll (0.35 cm)
Media Feeders
1 x manual - 1 roll - Roll (1.2 cm)
Media Included
1 12 mm x 4 m black on white laminated tape
No power supply
AAA type - Alkaline
Required Qty
6
Included
0
11.5 cm
6.1 cm
11.5 cm
380 g
Ink (14)
HWZS Brother TZES221 Black on White 9mm In Stock £5.88
HWZS Brother TZe-S211 - laminated tape - 1 cassette(s) - Roll (0.6 cm x 8 m) In Stock £9.83
HWZS Brother Laminated Tape 12mm Blk on Yel In Stock £9.07
HWZS Brother Tape Black on Yellow 6mm In Stock £7.72
HWZS Brother TZE-335 LAMINATED TAPE 12MM 8M In Stock £11.31
HWZS Brother Tape Black on Yellow 12mm In Stock £11.18
HWZS Brother Black On Clear Labelling Tape 12mm In Stock £8.69
HWZS Brother 12mm Black on White Tape In Stock £11.78
HWZS Brother Tape Black on Clear 9mm In Stock £7.72
HWZS Brother 12mm Matt Black on Red Laminated Tape In Stock £10.18
HWZS Brother 12mm Blue on White Tape In Stock £10.18
HWZS Brother P-touch TZe-211 (6mm x 8m) Black On White Label Tape In Stock £7.58
HWZS Brother TZE621 9MM GLOSS Black on Yellow Tape In Stock £8.69
HWZS Brother TZEFX-231 Black On White Flexi Tape In Stock £11.78
Other bundles (1)
HWZS Brother TZe 231 - laminated adhesive tape - 1 roll(s) In Stock £9.61
Type: Printer
Brand: Brother
