The Brother P-Touch PT-P300BT is the Bluetooth label printer that works with your smartphone or tablet via P-Touch Design&Print app that comes with print-ready templates and frames.
Organize your home
Try out the useful templates with pre-made labels and pattern designs. From labeling file folders, cables and wires, to making gift tags and scrapbook pages, there are more uses than ever for the PT-P300BT. -
Print anywhere, anytime
Use the Design&Print app and design labels from your smartphone. -
Compact and portable design
Built to fit into any home or office environment. It's lighter and smaller than any other similar products in the market today. -
High speed printing
The fast thermal label printer in its class with high print speed. -
Expand your creativity with a great range of tapes
With a great range of different tapes to choose from the possibilities are endless. Create stylish ribbon, decorative and laminated durable tapes that will add extra flair to your home or office.
- Brother P-Touch PT-P300BT - label printer - B/W - thermal transfer
- Printer Type
- Label printer - thermal transfer - B/W
- 380 g
- Max Media Size
- Roll (1.2 cm)
- Max Media Size (Custom)
- 12 mm
- Print Speed
- Up to 20 mm/sec
- Max Resolution (B&W)
- 180 dpi
- Cutter
- Interface
- Bluetooth 2.1 EDR
- Media Type
- Laminated tape
- Compatible Tapes
- TZe tape
- Styles & Effects
- Bold, vertical, italic, horizontal lines
- Battery
- Required 6 x AAA type Alkaline Included Qty 0
- 2-year warranty
- 11.5 cm x 6.1 cm x 11.5 cm
- Printer Type
- Label printer - thermal transfer - monochrome
Printer
- Print Speed
- Up to 20 mm/sec
- Interface
- Bluetooth 2.1 EDR
- 180 dpi
- Styles & Effects
- Cutter
Media Handling
- Media Type
- Laminated tape
- Compatible Tapes
- TZe tape
- Max Media Size
- Roll (1.2 cm)
- 12 mm
- Media Sizes
- Roll (0.6 cm), Roll (1.2 cm), Roll (0.9 cm), Roll (0.35 cm)
- Media Feeders
- 1 x manual - 1 roll - Roll (1.2 cm)
- Media Included
- 1 12 mm x 4 m black on white laminated tape
- Power Device
- No power supply
- AAA type - Alkaline
- Required Qty
- 6
- Included
- 0
- Limited warranty - 2 years
- 11.5 cm
- 6.1 cm
- 11.5 cm
- 380 g
Ink (13)
Brother TZES221 Black on White 9mm | In Stock | £5.88 |
Brother TZe-S211 - laminated tape - 1 cassette(s) - Roll (0.6 cm x 8 m) | In Stock | £9.83 |
Brother Laminated Tape 12mm Blk on Yel | In Stock | £9.10 |
Brother Tape Black on Yellow 6mm | In Stock | £7.72 |
Brother TZE-335 LAMINATED TAPE 12MM 8M | In Stock | £11.26 |
Brother Black On Clear Labelling Tape 12mm | In Stock | £8.69 |
Brother 12mm Black on White Tape | In Stock | £11.78 |
Brother Tape Black on Clear 9mm | In Stock | £7.72 |
Brother 12mm Matt Black on Red Laminated Tape | In Stock | £10.18 |
Brother 12mm Blue on White Tape | In Stock | £10.18 |
Brother P-touch TZe-211 (6mm x 8m) Black On White Label Tape | In Stock | £7.54 |
Brother TZE621 9MM GLOSS Black on Yellow Tape | In Stock | £8.69 |
Brother TZEFX-231 Black On White Flexi Tape | In Stock | £11.78 |
Other bundles (2)
Brother TZe 231 - laminated adhesive tape - 1 roll(s) | In Stock | £9.61 |
Brother Mains Adapter for PTouch Label Printers | In Stock | £11.87 |
