All of Brother's computer connectable label printers are supplied with advanced label-printing software in the box as standard. In addition to this software, there are other professional solutions available for download, or from your local Brother office.
Add the benefits of P-touch label printing directly from within your own existing software, or create your own totally customized labeling applications. By using the b-PAC SDK (Software Development Kit), your labels can contain any combination of text, barcodes, images and logos.
Efficient label making
The Brother P-Touch PT-M95 labelmaker is designed for quick and easy label creation, supporting a variety of media sizes including rolls up to 1.2 cm. Its built-in character keyboard and display with a resolution of 1 line x 12 characters enable seamless operation and preview of labels. -
Versatile printing options
With compatibility for M tape and features like 2 line printing, this printer offers flexibility for all your labeling needs. Whether you're organizing at home or in the office, the PT-M95 adapts to a range of tasks. -
Convenient and user-friendly
Equipped with a manual cutter and the ability to handle rolls up to 1.2 cm, the PT-M95 ensures a smooth labeling process from start to finish. Its manual media load type and feeder capacity for 1 roll streamline the preparation for printing.
- Brother P-Touch PT-M95 - labelmaker - B/W - thermal transfer
- Printer Type
- Labelmaker - thermal transfer - B/W
- 250 g
- Max Media Size
- Roll (1.2 cm)
- Min Media Size (Custom)
- 9 mm
- Max Media Size (Custom)
- 12 mm
- Print Speed
- Up to 7.5 mm/sec
- Max Resolution (B&W)
- 203 dpi
- Cutter
- Compatible Tapes
- M tape
- Fonts
- Helsinki
- Styles & Effects
- Vertical, underline
- 2 line printing
- Display Resolution
- 1 line x 12 characters
- Keyboard
- QWERTY / 45 keys
- Battery
- Required 4 x AAA type Alkaline
- 2-year warranty
- 11.1 cm x 15.6 cm x 6.1 cm
- Printer Type
- Labelmaker - thermal transfer - monochrome
Printer
- Print Speed
- Up to 7.5 mm/sec
- Built-in Devices
- Preview screen, character keyboard
- 203 dpi
- Fonts
- Helsinki
- Styles & Effects
- 2 line printing
- Cutter
- Keyboard
- QWERTY / 45 keys
Media Handling
- Compatible Tapes
- M tape
- Max Media Size
- Roll (1.2 cm)
- 9 mm
- 12 mm
- Media Sizes
- Roll (1.2 cm), Roll (0.9 cm)
- Media Feeders
- 1 x manual - 1 roll - Roll (1.2 cm)
- Media Included
- 1 12 mm x 4 m black on white M tape
- Power Device
- No power supply
- AAA type - Alkaline
- Required Qty
- 4
- Limited warranty - 2 years - carry-in
- 11.1 cm
- 15.6 cm
- 6.1 cm
- 250 g
- Width (Shipping)
- 20.4 cm
- Depth (Shipping)
- 19.3 cm
- Height (Shipping)
- 8.6 cm
- Weight (Shipping)
- 650 g
Brother Rubbon PT-55 Larg 12 | In Stock | £5.99 |
Brother Black on White 9mm 4 M Tape | In Stock | £3.37 |
Brother M K221BZ Label Tape (Black on White) | In Stock | £5.44 |
