Being more efficient and better organised is easy with the PT-H105, which delivers professional-looking laminated labels at the touch of a button.
From your files and equipment to your shelving units, this handheld label printer helps you to keep everything straight at home or in the office, while the lightweight design and soft touch keys means it's especially simple to use.
Offering nine font styles and a wide range of symbols, the PT-H105 also lets you design creative labels through the Deco Mode feature. You can personalise your labels by adding a frame, and even preview your work before you print.
- Brother P-Touch PT-H105 - labelmaker - B/W - thermal transfer
- Printer Type
- Labelmaker - thermal transfer - B/W
- Form Factor
- Portable
- 390 g
- Max Media Size
- Roll (1.2 cm)
- Min Media Size (Custom)
- 3.5 mm
- Max Media Size (Custom)
- 12 mm
- Print Speed
- Up to 20 mm/sec
- Max Resolution (B&W)
- 180 dpi
- Cutter
- Media Type
- Laminated labels
- Compatible Tapes
- TZe tape
- Fonts
- Helsinki
- Styles & Effects
- Bold, italic bold, italic outline, italic shadow, normal, vertical, outline, shadow, italic, underline
- 2 line printing
- Display Resolution
- 1 line x 12 characters
- Keyboard
- ABCD / 54 keys
- Battery
- Required 6 x AAA type Alkaline
- 3-year warranty with product registration
- 11 mm x 5.9 cm x 20.7 cm
- Printer Type
- Labelmaker - thermal transfer - monochrome
Printer
- Print Speed
- Up to 20 mm/sec
- Built-in Devices
- Preview screen, character keyboard
- 180 dpi
- Fonts
- Helsinki
- Styles & Effects
- 2 line printing
- Cutter
- Keyboard
- ABCD / 54 keys
- Repeating Printing
- 9 copies
Media Handling
- Media Type
- Laminated labels
- Compatible Tapes
- TZe tape
- Max Media Size
- Roll (1.2 cm)
- 3.5 mm
- 12 mm
- Media Sizes
- Roll (0.6 cm), Roll (1.2 cm), Roll (0.9 cm), Roll (0.35 cm)
- Max Printing Width
- 9 mm
- Media Included
- 1 12 mm x 4 m black on white laminated tape
- Auto on/off
- Power Device
- No power supply
- AAA type - Alkaline
- Required Qty
- 6
- Limited warranty - 3 years - carry-in
- 11 mm
- 5.9 cm
- 20.7 cm
- 390 g
