Brother PT-E100VP Labelling Machine
Quicklinx: 8VHDWS00 Mfr#: PTE100VPZU1
It is the newest member of the P-touch EDGE family of industrial handheld labelling systems which give contractors the competitive edge so that they can become more productive by labelling the job quickly and efficiently. The PT-E100 is designed to be simple to use just pick it up type and then print the right looking label. Brother helps you master using the PT-E100 virtually without reading a manual or going through the learning curve. Label application keys help you label cables by selecting the diameter of a cable or the width of a label that will fit precisely on a faceplate. By integrating smart layout features with intuitive navigation and easy to understand display messaging the PT-E100 can help you label just about anything that comes up. The PT-E100 uses Brother HGe tapes that come in an easy to load drop in cartridge which contains all the necessary components within the cartridge to print a laminated label. Using an innovative laminating thermal transfer printing engine with smart sensing technology the labelling system will make automatic imaging settings that helps print a near perfect laminated label every time including the ability to produce UL recognized labels that withstand fading abrasion extreme temperatures harsh chemicals and moisture. The contractor's work represents the best in service quality and performance. As an important element of documenting the job labels are seen as a thumbprint of professionalism and the Brother laminated labels help make their work look as good as it performs.
