Keeping labelling clear and consistent can be a problem when everyone is producing their own versions from different devices and printers. That's when the network-ready PT-9800PCN really comes into its own.
Now multiple users can access the same professional labelling resource, with print speeds up to an impressive 80mm per second and resolution of up to 720 x 360dpi. The labelling software is held on the network too, so there's no need to upload to every PC and laptop individually.
Particularly useful when you need to produce lots of labels at once, the PT-9800PCN is especially suited for use in manufacturing, around offices and in the post room.
Versatile connectivity
Equipped with LAN, USB host, and serial interfaces, this label printer offers flexible connection options to seamlessly integrate into any existing workflow. -
Efficient media handling
Supports a wide range of media sizes from Roll (0.6 cm) to Roll (3.6 cm), accommodating various labeling needs with ease. -
High-speed printing
Achieves a maximum printing speed of 80 mm/s, ensuring quick and efficient label production for busy environments. -
Durable design
Features an auto cutter and compatibility with HG and TZ tapes, making it capable of producing long-lasting, laminated labels for any application. -
Comprehensive compatibility
Designed to work flawlessly with both Mac and PC systems, this printer is a versatile solution for any office setting.
- Brother P-Touch PT-9800PCN - label printer - B/W - thermal transfer
- Printer Type
- Label printer - thermal transfer - B/W
- 1.6 kg
- Max Media Size
- Roll (3.6cm)
- Max Media Size (Custom)
- 36 mm
- Print Speed
- Up to 80 mm/sec , Up to 52 mm/sec , Up to 20 mm/sec
- Max Resolution (B&W)
- 360 x 720 dpi
- Cutter
- Interface
- USB, LAN, serial, USB host
- Media Type
- Laminated tape
- Compatible Tapes
- TZ tape, HG tape
- Styles & Effects
- Bold, normal, outline, shadow, italic, Mirror, underline, rotated text, frame, shadow light, surround
- Networking
- Print server - Ethernet, Fast Ethernet
- Microsoft Certification
- Compatible with Windows 7
- 11.6 cm x 19.3 cm x 14 cm
- Printer Type
- Label printer - thermal transfer - monochrome
Printer
- Print Speed
- Connectivity Technology
- Wired
- Interface
- 360 x 720 dpi
- Styles & Effects
- Auto Cutter
- Repeating Printing
- 5000 copies
Media Handling
- Media Type
- Laminated tape
- Compatible Tapes
- TZ tape, HG tape
- Max Media Size
- Roll (3.6cm)
- 36 mm
- Media Sizes
- Roll (2.4 cm), Roll (0.6 cm), Roll (1.8 cm), Roll (1.2 cm), Roll (0.9 cm), Roll (3.6cm)
- Media Feeders
- 1 x manual - 1 roll - Roll (3.6cm)
- Networking
- Print server
- Data Link Protocol
- Connections
- 1 x RS-232 , 1 x USB - 4 pin USB Type B , 1 x LAN - RJ-45 , 1 x direct print port - 4 pin USB Type A
- Power Device
- Power adapter - external
- Software Included
- Brother P-touch Editor 5
- 10 °C
- 35 °C
- 20 - 80%
- 11.6 cm
- 19.3 cm
- 14 cm
- 1.6 kg
