Brother PT 9500PC
Brother PT 9500PC
Quicklinx: 495RWS00 Mfr#: PT9500PC
It's now easier than ever to create professional looking laminated labels right from your desktop. Create and print, it's as easy and 1-2-3. Those assets you've thought about labeling can now be done with labels that stick anywhere at any time. With the 9500PC you can create a strip of labels from your desktop so you can be off and labeling user machines in no time flat. This labeler also has an auto-cutter and can print "crack and peel" labels for easy peeling. Pre-design your labels with your company logo or other graphics, import your database, and print - labeling has never been easier.
The PT-9500PC connects to your PC or MAC and uses easy-swap tape cassettes allowing you to print laminated labels with standard or "industrial strength" adhesive (twice the adhesive strength) in a variety of fonts and styles. With built-in base code templates and symbols, the PT-9500PC delivers the performance and reliability you want in a label printer.
Brother P-Touch PT-9500pc - label printer - B/W - thermal transfer
Printer Type
Label printer - thermal transfer - B/W
1.2 kg
Max Media Size
Roll (3.6 cm x 8 m)
Max Media Size (Custom)
36 mm
Print Speed
Up to 20 mm/sec - B/W
Max Resolution (B&W)
360 dpi
Cutter
USB, serial
Barcodes
Code 39, UCC/EAN-128, ISBN, QR code, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Codabar, Code 128, Postnet, PDF417, Data Matrix
Media Type
Laminated tape, fabric tape, flexible tape
Compatible Tapes
TZ tape
Styles & Effects
Bold, normal, outline, shadow, italic, Mirror, underline, rotated text, frame, shadow light, surround
16 line printing
Total Media Capacity
1 roll
Microsoft Windows NT 4.0, Microsoft Windows 95/98, Apple MacOS 8.6 - 9.x, Microsoft Windows 98SE/2000/ME/XP, Apple MacOS X 10.2 - 10.2.6
Enclosure Colour
Black, blue, silver
1-year warranty
11.6 cm x 19 cm x 12.7 cm
Printer Type
Label printer - thermal transfer - monochrome
Enclosure Colour
Black, blue, silver
Printer
Print Speed
Wired
USB, serial
360 dpi
Styles & Effects
16 line printing
Auto Cutter
Repeating Printing
5000 copies
Barcodes
Media Handling
Media Type
Compatible Tapes
TZ tape
Max Media Size
Roll (3.6 cm x 8 m)
36 mm
Media Sizes
Roll (1.8 cm x 8 m), Roll (1.2 cm x 8 m), Roll (0.9 cm x 8 m), Roll (3.6 cm x 8 m), Roll (2.4 cm x 8 m), Roll (0.6 cm x 8 m)
1 roll
Media Feeders
1 x manual - 1 roll - Roll (3.6 cm x 8 m)
1 x RS-232 , 1 x USB - 4 pin USB Type B
Cutter catch tray
1 x USB cable , 1 x serial cable
Power adapter - external
Software Included
Drivers & Utilities
System Requirements Details
Windows 95/98 - RAM 64 MB - HD 70 MB , Windows 98SE/2000/ME/XP - RAM 64 MB - HD 70 MB , Windows NT 4.0 - RAM 64 MB - HD 70 MB , MacOS 8.6 - 9.x - RAM 24 MB - HD 100 MB , MacOS X 10.2 - 10.2.6 - RAM 24 MB - HD 100 MB
Limited warranty - 1 year
11.6 cm
19 cm
12.7 cm
1.2 kg
