Brother PocketJet PJ-662 A4 Thermal Mobile Printer
Quicklinx: 9K2DWS00 Mfr#: PJ662Z1
Get the job finished immediately by printing on the go with the PJ-662.
Easily carry this compact printer with you to meetings and appointments or keep it mounted in your vehicle – whichever's better suited to your line of work. You can also take your pick from a range of software features and accessories for a fully tailored print solution.
Connect via Bluetooth, IrDA or USB wherever you are. Plus the PJ-662's thermal printing system mean you're guaranteed great results no matter the conditions.
  • Effortless connectivity
    With both IrDA interfaces and wireless capabilities, the Brother PocketJet 6 PJ-662 ensures seamless connection to your devices, making it an ideal solution for on-the-go printing needs.
  • Compact and portable
    Designed for mobility, this personal printer boasts a lightweight, portable frame, enabling professionals to print high-quality documents anywhere, anytime.
  • High-quality monochrome output
    Leverage the direct thermal printing technology for sharp, black and white documents with a maximum resolution of 203 x 200 DPI, perfect for all your professional printing requirements.
  • Versatile media handling
    The Brother PocketJet 6 PJ-662 accommodates a variety of media sizes including A4 and types such as plain paper and continuous forms, offering flexibility for your printing tasks.
Brother PocketJet 6 PJ-662 - printer - B/W - direct thermal
Printer Type
Personal printer - direct thermal - B/W
Portable
473 g
Media Size Class
A4
Max Media Size
A4 (210 x 297 mm)
Print Speed
Up to 6 ppm - B/W
Max Resolution (B&W)
203 x 200 dpi
USB, Bluetooth, IrDA
Media Type
Plain paper, continuous forms
Print server - Bluetooth 2.0 EDR
Apple MacOS X, Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista
1-year warranty
25.5 cm x 5.5 cm x 3 cm
Printer Type
Personal printer - direct thermal - monochrome
Printer
Print Speed
Up to 6 ppm - B/W
Wireless
203 x 200 dpi
Media Handling
Media Type
Media Size Class
A4
Max Media Size
A4 (210 x 297 mm)
Media Sizes
A4 (210 x 297 mm)
Media Feeders
1 x manual - 1 sheet
Print server
Bluetooth 2.0 EDR
1 x IrDA - IrDA , 1 x USB - 4 pin USB Type B
Cleaning kit
1 x USB cable
Software Included
Brother P-touch Editor 5
Limited warranty - 1 year
25.5 cm
5.5 cm
3 cm
473 g
