Product
Brand
Brother PocketJet PJ-622 A4 Thermal Mobile Printer
Quicklinx: 9K2BWS00 Mfr#: PJ622Z1
Take the durable PJ-622 along with you when you're out on the road and you'll never have to keep your clients or customers waiting for those all-important documents.
With USB and IrDA interfaces for seamless connectivity, this compact and convenient printer helps you work more productively whether you need to print out invoices, contracts or service reports.
Perfectly sized for your briefcase or computer bag, the PJ-622 can also be easily mounted in your vehicle. And the direct thermal printing technology ensures reliable results, whatever the conditions or environment – and no risk of running out of ink at a vital moment.
Brother PocketJet 6 PJ-622 - printer - monochrome - direct thermal
Printer Type
Personal printer - direct thermal - monochrome
Portable
473 g
Media Size Class
A4
Max Media Size
Roll A4
Print Speed
Up to 6 ppm - B/W
Max Resolution (B&W)
203 x 200 dpi
USB, IrDA
Media Type
Thermal paper
Apple MacOS X, Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista
1 year warranty
25.5 cm x 5.5 cm x 3 cm
Printer Type
Printer
Print Speed
Up to 6 ppm - B/W
Wireless
USB, IrDA
203 x 200 dpi
Media Handling
Media Type
Thermal paper
Media Size Class
A4
Max Media Size
Roll A4
Media Sizes
Roll A4
Media Feeders
1 x manual
1 x IrDA - IrDA , 1 x USB - 4 pin USB Type B
Cleaning kit
1 x USB cable
Software Included
Brother P-touch Editor 5
Limited warranty - 1 year
25.5 cm
5.5 cm
3 cm
473 g
