Brother PJ-773 A4 Thermal Mobile Printer
Quicklinx: C35MWS00 Mfr#: PJ773Z1
Type: Printer
Functionality: Printer
Output Type: Monochrome
Wireless Capability: Wired, Wireless
Technology: Thermal Ink-jet
£432.66 ex VAT
£519.19 inc VAT
The PocketJet is the ultimate A4 portable print solution. The PocketJet fits easily into a briefcase or computer bag and can be effortlessly mounted in vehicles or other work areas. Due to its advanced thermal technology, you can print in any environment without having to deal with inks and toners, making it the perfect portable print solution. And, because the PocketJet prints in A4, it's ideal for printing documents onsite where more detailed information is required, such as invoices, service reports and delivery notes. So give your mobile workforce an advantage over the competition with the PocketJet, the great portable printers.
High quality A4 printing on the move
The Brother PJ range of mobile printers finally offer businesses a reliable way of producing high quality A4 sized prints wherever and whenever they are required. Featuring direct thermal printing, this technology is considered by many to be the only reliable solution for mobile print applications. And as no ink, toner or ribbons are used, this ensures workers don't have to source expensive replacements when they run out - the only consumable used is the paper itself.
Compact and lightweight
Despite its incredibly small size and lightweight design, the development and manufacturing process has been focussed on producing a durable, professional printer that can be carried in a briefcase or computer bag, or permanently mounted in a vehicle.
Integrate printing within your existing mobile apps and software
Enabling printing within existing apps or software used to be a difficult task. However, as well as standard printer drivers for Windows®, Mac and Linux, Brother has a range of SDK (Software Development Kits) that allow developers to easily add printing capabilities into existing solutions, or allow new printing apps to be developed quickly and efficiently. SDK's are available for iOS, Android and Windows® operating systems.
USB connectivity
Offering the reliability of a wired connection, you can connect to Windows®, Mac or Linux based desktops and laptops, or to Android devices that have USB Host support (requires Android OS ver 3.1 or later).
AirPrint™, Google Cloud Print and MOPRIA® support
Print directly from supported apps and desktop software, without needing to install printer drivers or integrate printing capabilities within apps. With support for the three most common wireless print standards found across many mobile devices, the PJ-773 gives you the most print options available in the PJ-700 range.
Brother PocketJet PJ-773 - printer - B/W - direct thermal
Printer Type
Personal printer - direct thermal - B/W
Portable
480 g
Media Size Class
A4
Max Media Size
216 x 5490 mm
Min Media Size (Custom)
105 mm x 25.4 mm
Max Media Size (Custom)
216 mm x 5490 mm
Print Speed
Up to 8 ppm - B/W
Max Resolution (B&W)
300 x 300 dpi
USB 2.0, Wi-Fi(n)
AirPrint Enabled
RAM Installed (Max)
32 MB
Flash Memory Installed (Max)
6 MB
Language Simulation
EPSON ESC/P, EPSON ESC/P Raster
Barcodes
Code 93, Industrial 2 of 5, Code 39, GS1 DataBar, QR code, MaxiCode, Aztec code, UPC-A, UPC-E, MicroPDF417, Code 128, Postnet, PDF417, Data Matrix, ITF, Micro QR code, EAN-8, EAN-13, MSI, GS1-128
Media Type
Thermal paper
Print server
Linux, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2008, Windows 8, Microsoft Windows Server 2012, Android 2.3 or later, Apple MacOS X 10.8, Apple iOS 5.0 or later, Microsoft Windows Server 2012 R2, Windows 8.1, Apple MacOS X 10.9, Apple MacOS X 10.10, Windows 10
Microsoft Certification
Compatible with Windows 7
3-year warranty
25.5 cm x 5.5 cm x 3 cm
Printer Type
Personal printer - direct thermal - monochrome
Printer
Print Speed
Up to 8 ppm - B/W
Wireless
USB 2.0, Wi-Fi(n)
AirPrint Enabled
300 x 300 dpi
Language Simulation
Barcodes
RAM
RAM Installed (Max)
32 MB
Flash Memory
Flash Memory
6 MB
Media Handling
Media Type
Thermal paper
Media Size Class
A4
Max Media Size
216 x 5490 mm
105 mm x 25.4 mm
216 mm x 5490 mm
Media Sizes
A4 (210 x 297 mm)
Media Feeders
1 x manual - 1 sheet - 216 x 5490 mm
Print server
1 x USB 2.0 - 4 pin mini-USB Type B
Head cleaner
1 x USB cable
Limited warranty - 3 years
25.5 cm
5.5 cm
3 cm
480 g
Type: Printer
Wireless Capability: Wireless
Max Print Speed: 8ppm
Max Paper Size: 216 x 5490 mm
Brand: Brother
Price Range Ex VAT: 300 - 500
