Print quotations, invoices, and other reports whilst on the move and streamline the work of field sales, field service, logistics, delivery and the emergency service sectors. The PJ-763 with built-in Bluetooth and USB connectivity offers a mobile A4 print solution compact enough to fit easily into a briefcase or computer bag, but that can also be permanently installed in vehicles. Thermal print technology at 300dpi produces crisp text at a print speed of up to 8 pages per minute. Compatible with a wide range of mobile and desktop operating systems, the PJ-763 can easily be integrated into your own apps and software using the various SDK's (Software Development Kits) available.
PJ-763 high-resolution direct thermal mobile printer with Bluetooth
This rugged and durable "in the field" printer is an ideal printing solution for sales/service, logistics/delivery and public safety/emergency officials. The Bluetooth and USB connections conveniently link to tablets, smartphones, PC's and laptops. It offers a fully portable and lightweight printing solution that's not much wider than an A4 sheet of paper, making it ideal for carrying in a bag or being mounted in a vehicle or a specialist case, as part of a complete mobile solution. The PJ-763 can print at up to 8 pages per minute, at a resolution of 300dpi on either cut-sheets, or continuous rolls that can easily be torn off. Support for up to A4 sized paper makes it ideal for invoices, service reports and delivery reports. A wide range of accessories are available to customise your mobile print solution to your requirements.
High quality A4 printing on the move
The Brother PJ range of mobile printers finally offer businesses a reliable way of producing high quality A4 sized prints wherever and whenever they are required. Featuring direct thermal printing, this technology is considered by many to be the only reliable solution for mobile print applications. And as no ink, toner or ribbons are used, this ensures workers don't have to source expensive replacements when they run out - the only consumable used is the paper itself.
Compact and lightweight
Despite its incredibly small size and lightweight design, the development and manufacturing process has been focussed on producing a durable, professional printer that can be carried in a briefcase or computer bag, or permanently mounted in a vehicle.
Integrate printing within your existing mobile apps and software
Enabling printing within existing apps or software used to be a difficult task. However, as well as standard printer drivers for Windows®, Mac and Linux, Brother has a range of SDK (Software Development Kits) that allow developers to easily add printing capabilities into existing solutions, or allow new printing apps to be developed quickly and efficiently. SDK's are available for iOS, Android and Windows® operating systems.
USB connectivity
Offering the reliability of a wired connection, you can connect to Windows®, Mac or Linux based desktops and laptops, or to Android devices that have USB Host support (requires Android OS ver 3.1 or later).
Effortless connectivity
With both Bluetooth 2.1 EDR and USB 2.0 interfaces, this printer offers versatile connectivity options, allowing for easy integration into your existing workflow. -
High-quality monochrome printing
Leveraging direct thermal printing technology, the Brother PocketJet PJ-763 delivers high-quality monochrome outputs, ensuring your documents look professional every time. -
Portable design
Designed with portability in mind, this compact printer is an ideal solution for on-the-go printing needs, making it perfect for field work or mobile offices. -
Flexible media handling
Accommodates a wide range of media sizes up to 216 x 5490 mm, including A4, providing the flexibility needed to complete various printing tasks. -
Efficient output
Achieve printing speeds of up to 8 pages per minute with a maximum resolution of 300 x 300 DPI, enhancing productivity without sacrificing quality.
- Brother PocketJet PJ-763 - printer - B/W - direct thermal
- Printer Type
- Personal printer - direct thermal - B/W
- Form Factor
- Portable
- 480 g
- Media Size Class
- A4
- Max Media Size
- 216 x 5490 mm
- Min Media Size (Custom)
- 105 mm x 25.4 mm
- Max Media Size (Custom)
- 216 mm x 5490 mm
- Print Speed
- Up to 8 ppm - B/W
- Max Resolution (B&W)
- 300 x 300 dpi
- Interface
- USB 2.0, Bluetooth 2.1 EDR
- RAM Installed (Max)
- 32 MB
- Flash Memory Installed (Max)
- 6 MB
- Language Simulation
- EPSON ESC/P, EPSON ESC/P Raster
- Barcodes
- Code 93, Industrial 2 of 5, Code 39, GS1 DataBar, QR code, MaxiCode, Aztec code, UPC-A, UPC-E, MicroPDF417, Code 128, Postnet, PDF417, Data Matrix, ITF, Micro QR code, EAN-8, EAN-13, MSI, GS1-128
- Media Type
- Thermal paper
- Networking
- Print server
- System Requirements
- Linux, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2008, Windows 8, Microsoft Windows Server 2012, Apple OS X 10.8 Mountain Lion, Android 2.3 or later, Microsoft Windows Server 2012 R2, Windows 8.1, Apple OS X 10.9 Mavericks, Apple MacOS X 10.10, Windows 10
- Microsoft Certification
- Compatible with Windows 7
- 3-year warranty
- 25.5 cm x 5.5 cm x 3 cm
- Printer Type
- Personal printer - direct thermal - monochrome
Printer
- Print Speed
- Up to 8 ppm - B/W
- Connectivity Technology
- Wireless
- Interface
- 300 x 300 dpi
- Barcodes
RAM
- 32 MB
Flash Memory
- Flash Memory
- 6 MB
Media Handling
- Media Type
- Thermal paper
- Media Size Class
- A4
- Max Media Size
- 216 x 5490 mm
- 105 mm x 25.4 mm
- 216 mm x 5490 mm
- Media Sizes
- A4 (210 x 297 mm)
- Media Feeders
- 1 x manual - 1 sheet - 216 x 5490 mm
- Networking
- Print server
- Connections
- 1 x USB 2.0 - 4 pin mini-USB Type B
- Included Accessories
- Head cleaner
- Cables Included
- 1 x USB cable
- OS Required
- Limited warranty - 3 years
- 25.5 cm
- 5.5 cm
- 3 cm
- 480 g
