This rugged and durable "in the field" printer is an ideal printing solution for sales/service, logistics/delivery and public safety/emergency officials. The USB connection conveniently links to your PC's and laptops. It offers a fully portable and lightweight printing solution that's not much wider than an A4 sheet of paper, making it ideal for carrying in a bag or being mounted in a vehicle or a specialist case, as part of a complete mobile solution. The PJ-723 can print at up to 8 pages per minute, at a resolution of 300dpi on either cut-sheets, or continuous rolls that can be easily torn off. Support for up to A4 sized paper makes it ideal for invoices, service reports and delivery reports. A wide range of accessories are available to customise your mobile print solution to your requirements.
High quality A4 printing on the move
The Brother PJ range of mobile printers finally offer businesses a reliable way of producing high quality A4 sized prints wherever and whenever they are required. Featuring direct thermal printing, this technology is considered by many to be the only reliable solution for mobile print applications. And as no ink, toner or ribbons are used, this ensures workers don't have to source expensive replacements when they run out - the only consumable used is the paper itself.
Compact and lightweight
Despite its incredibly small size and lightweight design, the development and manufacturing process has been focussed on producing a durable, professional printer that can be carried in a briefcase or computer bag, or permanently mounted in a vehicle.
Integrate printing within your existing mobile apps and software
Enabling printing within existing apps or software used to be a difficult task. However, as well as standard printer drivers for Windows®, Mac and Linux, Brother has a range of SDK (Software Development Kits) that allow developers to easily add printing capabilities into existing solutions, or allow new printing apps to be developed quickly and efficiently. SDK's are available for iOS, Android and Windows® operating systems.
USB connectivity
Offering the reliability of a wired connection, you can connect to Windows®, Mac or Linux based desktops and laptops, or to Android devices that have USB Host support (requires Android OS ver 3.1 or later).
                Compact designThe Brother PocketJet PJ-723 is designed with portability in mind, making it an ideal solution for on-the-go printing needs. Its compact size allows for easy transport and setup in any mobile environment, from vehicles to field workstations.
                Versatile connectivityEquipped with a USB 2.0 interface, the PJ-723 offers reliable wired connectivity, ensuring seamless integration with a wide range of devices for straightforward, hassle-free printing.
                Broad barcode supportThis printer stands out for its extensive barcode printing capabilities, supporting a wide array of barcode standards including QR codes, Data Matrix, and more, making it a versatile tool for various professional applications requiring barcode printing.
                Efficient monochrome printingWith a maximum printing speed of 8 pages per minute and support for monochrome output, the PJ-723 delivers efficient and high-quality printing performance for all your black and white documents.
                Direct thermal printing technologyLeveraging direct thermal printing technology, the PJ-723 eliminates the need for ink or toner, offering a cost-effective and low-maintenance solution for printing on thermal paper.
- Brother PocketJet PJ-723 - printer - B/W - direct thermal
- Printer Type
- Personal printer - direct thermal - B/W
- Form Factor
- Portable
- 480 g
- Media Size Class
- A4
- Max Media Size
- 216 x 5490 mm
- Min Media Size (Custom)
- 105 mm x 25.4 mm
- Max Media Size (Custom)
- 216 mm x 5490 mm
- Print Speed
- Up to 8 ppm - B/W
- Max Resolution (B&W)
- 300 x 300 dpi
- Interface
- USB 2.0
- RAM Installed (Max)
- 32 MB
- Flash Memory Installed (Max)
- 6 MB
- Language Simulation
- EPSON ESC/P, EPSON ESC/P Raster
- Barcodes
- Code 93, Industrial 2 of 5, Code 39, GS1 DataBar, QR code, MaxiCode, Aztec code, UPC-A, UPC-E, MicroPDF417, Code 128, Postnet, PDF417, Data Matrix, ITF, Micro QR code, EAN-8, EAN-13, MSI, GS1-128
- Media Type
- Thermal paper
- System Requirements
- Linux, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2008, Windows 8, Microsoft Windows Server 2012, Apple OS X 10.8 Mountain Lion, Android 3.1 (Honeycomb) or later, Microsoft Windows Server 2012 R2, Windows 8.1, Apple OS X 10.9 Mavericks, Apple MacOS X 10.10, Windows 10
- Microsoft Certification
- Compatible with Windows 7
- 3-year warranty
- 25.5 cm x 5.5 cm x 3 cm
- Printer Type
- Personal printer - direct thermal - monochrome
Printer
- Print Speed
- Up to 8 ppm - B/W
- Connectivity Technology
- Wired
- Interface
- USB 2.0
- 300 x 300 dpi
- Barcodes
RAM
- 32 MB
Flash Memory
- Flash Memory
- 6 MB
Media Handling
- Media Type
- Thermal paper
- Media Size Class
- A4
- Max Media Size
- 216 x 5490 mm
- 105 mm x 25.4 mm
- 216 mm x 5490 mm
- Media Sizes
- A4 (210 x 297 mm)
- Media Feeders
- 1 x manual - 1 sheet - 216 x 5490 mm
- Connections
- 1 x USB 2.0 - 4 pin mini-USB Type B
- Included Accessories
- Head cleaner
- Cables Included
- 1 x USB cable
- OS Required
- Limited warranty - 3 years
- 25.5 cm
- 5.5 cm
- 3 cm
- 480 g
