Brother PDS-5000F A4 Flatbed Scanner
Quicklinx: BW6NWS00 Mfr#: PDS5000FZ1
  • Windows 8.1 (32/64 bits)
  • Windows 8 (32/64 bits)
Impressive paper handling functions and a range of advanced image processing capabilities with the option to scan various media types with the integrated flatbed. Ideal for batch scanning and archiving, make repetitive workflow processes quicker and more efficient.
  • Efficient scanning
    With automatic duplexing and a robust duty cycle of 6,000 scans per day, this scanner is designed to handle high-volume workloads with ease. Its 100-sheet feeder capacity further enhances productivity, allowing for continuous scanning without frequent interruptions.
  • Versatile compatibility
    Designed to work seamlessly with both Mac and PC, the PDS-5000F offers flexible connectivity options through its USB 3.0 interface, ensuring a smooth integration into any existing workflow.
  • Advanced image quality
    The scanner's Dual CCD scanning sensor and a maximum optical resolution of 600 DPI deliver high-quality scans in both color and grayscale. With 24-bit color depth and 8-bit grayscale depth, images and documents are captured with exceptional detail and color fidelity.
  • Comprehensive document handling
    Supports a wide range of document types including business cards, plain paper, and plastic cards. Its versatile document feeder accommodates sizes up to 218 x 5994 mm, making it ideal for scanning a variety of documents.
  • Eco-friendly design
    ENERGY STAR certification ensures that the PDS-5000F is not only powerful but also energy-efficient, reducing operational costs and supporting sustainability initiatives.
Brother PDS-5000F - document scanner - desktop - USB 3.0
Document scanner - desktop
Interface Type
USB 3.0
Scanning Sensor Type
Dual CCD
Additional Functions
Email, scan to print, scan to FTP, scan to file
Max Supported Document Size
218 x 5994 mm
Input Type
Grayscale / Color Depth
8-bit (256 colours) / 24-bit (16.7 million colours)
Grayscale / Color Depth (External)
48-bit colour
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
60 ppm (mono) / 60 ppm (colour)
Max Document Size
218 mm x 5994 mm
Automatic Duplexing
Supported Document Type
Plain paper, business card, plastic card
Document Feeder Type
Manual, automatic
Document Storage Capacity
100 sheets
Duty Cycle
6000 scans per day
Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Apple OS X 10.8 Mountain Lion, Windows 8 (32/64 bits), Windows 8.1 (32/64 bits), Apple OS X 10.9 Mavericks, Apple MacOS X 10.10
32.3 cm x 61.3 cm x 26.3 cm
9.2 kg
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Interface Type
USB 3.0
218 x 5994 mm
Scanner
Input Type
Grayscale Depth
8-bit (256 colours)
Colour Depth
Colour Depth (External)
48-bit colour
Optical Resolution
600 dpi x 600 dpi
Scan Mode
Single-pass
Automatic Duplexing
Dual CCD
Max Document Scan Speed B/W
60 ppm
Max Document Scan Speed Colour
60 ppm
Duty Cycle
6000 scans per day
Scanner Speed Details
60 ppm - black & white - A4 - 300 dpi , 60 ppm - colour - A4 - 300 dpi , 120 ipm - duplex - black & white - 300 dpi , 120 ipm - duplex - colour - 300 dpi , 15 ppm - black & white - 600 dpi , 15 ppm - colour - 600 dpi , 30 ipm - duplex - black & white - 600 dpi , 30 ipm - duplex - colour - 600 dpi , 1.8 sec/scan - greyscale - A4 - 300 dpi , 1.8 sec/scan - colour - A4 - 300 dpi , 7.6 sec/scan - greyscale - A4 - 600 dpi , 7.6 sec/scan - colour - A4 - 600 dpi
Scanner Features
2 line x 16 character LCD, Kofax VRS compatibility
TWAIN, ISIS, WIA
Media Handling
Max Document Size
218 mm x 5994 mm
Supported Document Size Details
ADF - up to 218 x 5994 mm , Flatbed - up to 216 x 356 mm
Manual, automatic
100 sheets
Interfaces Details
USB 3.0
Carrier sheet, plastic card carrier sheet
1 x SuperSpeed USB cable
ENERGY STAR Certified
External power adapter
Power Consumption Operational (Standby)
53 Watt
Power Consumption Stand by
17.6 Watt
Software Included
Drivers & Utilities
32.3 cm
61.3 cm
26.3 cm
9.2 kg
Shipping Width
73 cm
Shipping Depth
43.9 cm
Shipping Height
38.6 cm
Shipping Weight
12.3 kg
Limited warranty - 1 year
5 °C
35 °C
20 - 80%
