Brother PA-BT-500 Printer Battery - NiMH
Quicklinx: 9BNNWS00 Mfr#: PABT500
£39.84 ex VAT
£47.80 inc VAT
Marketing description is not available.
  • Extended mobility
    Equipped with nickel metal hydride technology, the PA-BT-500 printer battery offers reliable power and extended mobility for all your printing needs. This ensures you can keep your printer operational, even when you're on the move
  • Seamless compatibility
    Designed specifically for PC compatibility, the PA-BT-500 ensures a seamless integration with your existing devices. This compatibility eliminates the hassle of dealing with incompatible components, making it easier to maintain productivity
Brother PA-BT-500 - printer battery - NiMH
Printer battery
Nickel Metal Hydride
PocketJet PJ-520, PJ-560, PJ-663, PJ-673, PJ-673-K; PocketJet 3 PJ-522, PJ-522 In-Vehicle Kit, PJ-523, PJ-562, PJ-563, Plus PJ-522, Plus PJ-523, Plus PJ-563; 6 PJ-622, PJ-623, PJ-662, PJ-663, PJ-673
Printer battery
Brother PocketJet PJ-520, PJ-560, PJ-663, PJ-673, PJ-673-K , Brother PocketJet 3 PJ-522, PJ-522 In-Vehicle Kit, PJ-523, PJ-562, PJ-563, Plus PJ-522, Plus PJ-523, Plus PJ-563 , Brother PocketJet 6 PJ-622, PJ-623, PJ-662, PJ-663, PJ-673
Brand: Brother
