Brother P-Touch TD2130N Label Printer
Quicklinx: 95YJWS00 Mfr#: TD2130NZU1
Type: Printer
Functionality: Printer
Output Type: Monochrome
Wireless Capability: Wired
Technology: Thermal transfer
Hurry, only 3 left in stock!
£340.01 ex VAT
£408.01 inc VAT
Designed for use on a cart or virtually any retail work space, the TD-2130N is among the most compact and fast 2.2-inch wide powered desktop/network thermal printers for retail applications. At 300-dpi, it prints price, mark-down, product identification, returns and shelf-edge labels quickly at up to 6-ips. Also prints tags and receipts for kiosk and POS applications. An innovative drop-in roll, spindle-less design helps make loading easy with existing or standard converted media.
  • Bridges the gap between desktop and mobile printers
    With the rechargeable battery, these printers become powered desktop thermal printers and operate like a mobile printer with higher media capacity and desktop printer options like a peeler and a touch panel LCD display for use off-line or as a standalone solution.
  • Print on a cart
    Brother designed these printers with a compact footprint to help provide the most usable work space on a cart versus nearly all competitive printers in its class. The Li-ion rechargeable battery option does not increase the compact footprint and provides mobility to a desktop thermal printer.
  • Standalone printing solution
    A touch panel and LCD display option is available for printing labels, tags or receipts off-line or as a standalone printer without a computer or a mobile device. Ideal for on-demand printing of price and "best before" freshness labels right in a food preparation area, or download information from a database and print shelf-edge, price and mark-down tags and labels in-aisle.
  • Small size, but big on performance
    Although these printers are among the smallest desktop thermal printers in their class, they also lead in performance over many 300 dpi print resolution desktop thermal printers.
  • Ergonomic design
    Uses an innovative spindle-less design that accepts labels, tags or receipt media with virtually any core size for a true drop-in media roll loading experience on a desktop, cart or even mounted to a wall.
  • Battery powered model
    Powered desktop and network thermal printer model configurations are available with a long life rechargeable Lithium-ion battery and charged by the printer power adapter or optional external 4-bay charger.
  • Print from mobile devices
    Brother provides iOS, Android and Windows Mobile SDK's to help develop a wireless printing solution from virtually any tablet or handheld device.
  • Print from a database
    Helps save time and increase accuracy by printing labels, tags and receipts linked directly to Microsoft SQL Server, Access or Excel database files.
  • Easy to integrate
    It comes with Windows Server and Windows printer drivers help make integration into existing retail systems seamless and simple.
  • Adjustable edge-to-edge media sensor
    It is flexibility to detect and print on more types of existing thermal media to help avoid converting custom media.
Brother TD-2130N - label printer - monochrome - direct thermal
Printer Type
Label printer - direct thermal - monochrome
1.34 kg
Max Media Size
Roll (6.3 cm)
Min Media Size (Custom)
19 mm
Max Media Size (Custom)
63 mm
Max Resolution (B&W)
300 dpi
USB 2.0, LAN, serial, USB host
RAM Installed (Max)
6 MB
Language Simulation
EPSON ESC/P, ZPL II, EPSON ESC/P Raster
Barcodes
Code 93, Code 39, UCC/EAN-128, QR code, MaxiCode, Aztec code, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, MicroPDF417, Codabar, Code 128, PDF417, Data Matrix, ITF, Truncated PDF417, Micro QR code
Media Type
Receipt paper, paper tag, die cut labels, wristband labels
Compatible Tapes
RD tape
Fonts
Brussels, Helsinki, San Diego, Letter Gothic Bold
Styles & Effects
Bold, Mirror
Black Mark sensor, gap sensor
Print server
AC 120/230 V
Microsoft Windows XP, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2008, Windows 8, Microsoft Windows Server 2012
3-year warranty
11.1 cm x 21.5 cm x 17.2 cm
Printer Type
Printer
Wired
300 dpi
Language Simulation
Fonts
Styles & Effects
Bold, Mirror
Auto Cutter
Barcodes
RAM
RAM Installed (Max)
6 MB
Media Handling
Media Type
Compatible Tapes
RD tape
Max Media Size
Roll (6.3 cm)
19 mm
63 mm
Media Sizes
Roll (6.3 cm)
Max Printing Width
56 mm
Max Printing Length
1 m
Media Thickness Range
0.058 mm - 0.279 mm
Roll Maximum Outer Diameter
127 mm
Roll Core Diameter
25.4 mm
Print server
1 x RS-232 - 9 pin D-Sub (DB-9) , 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type A
1 x USB cable
AC 120/230 V
Frequency Required
50/60 Hz
Software Included
Driver
Limited warranty - 3 years
5 °C
20 - 80% (non-condensing)
11.1 cm
21.5 cm
17.2 cm
1.34 kg
Type: Printer
Max Print Speed: [N/A]
Max Paper Size: Roll (6.3 cm)
Brand: Brother
Price Range Ex VAT: 300 - 500
