Designed for use on a cart or virtually any retail work space, the TD-2120N is among the most compact and fastest 2.2-inch wide powered desktop/network thermal printers for retail applications. At 203dpi, it prints price, mark-down, product identification, returns and shelf-edge labels quickly at up to 6ips. Also prints tags and receipts for kiosk and POS applications. An innovative drop-in roll, spindle-less design helps make loading easy with existing or standard converted media.
Bridges the gap between desktop and mobile printers
With the rechargeable battery, these printers become powered desktop thermal printers and operate like a mobile printer with higher media capacity and desktop printer options like a peeler and a touch panel LCD display for use off-line or as a standalone solution. -
Print on a cart
Brother designed these printers with a compact footprint to help provide the most usable work space on a cart versus nearly all competitive printers in its class. The Li-ion rechargeable battery option does not increase the compact footprint and provides mobility to a desktop thermal printer. -
Standalone printing solution
A touch panel and LCD display option is available for printing labels, tags or receipts off-line or as a standalone printer without a computer or a mobile device. Ideal for on-demand printing of price and "best before" freshness labels right in a food preparation area, or download information from a database and print shelf-edge, price and mark-down tags and labels in-aisle. -
Small size, but big on performance
Although these printers are among the smallest desktop thermal printers in their class, they also lead in performance over many 203 dpi print resolution desktop thermal printers. -
Ergonomic design
Uses an innovative spindle-less design that accepts labels, tags or receipt media with virtually any core size for a true drop-in media roll loading experience on a desktop, cart or even mounted to a wall. -
Print from a database
Helps save time and increase accuracy by printing labels, tags and receipts linked directly to Microsoft SQL Server, Access or Excel database files. -
Adjustable edge-to-edge media sensor
Flexibility to detect and print on more types of existing thermal media to help avoid converting custom media.
- Brother TD-2120N - label printer - B/W - direct thermal
- Printer Type
- Label printer - direct thermal - B/W
- 1.34 kg
- Max Media Size
- Roll (6.3 cm)
- Min Media Size (Custom)
- 19 mm
- Max Media Size (Custom)
- 63 mm
- Max Resolution (B&W)
- 203 dpi
- Cutter
- Interface
- USB 2.0, LAN, serial, USB host
- RAM Installed (Max)
- 6 MB
- Language Simulation
- EPSON ESC/P, ZPL II, EPSON ESC/P Raster
- Barcodes
- Code 93, Code 39, UCC/EAN-128, QR code, MaxiCode, Aztec code, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, MicroPDF417, Codabar, Code 128, PDF417, Data Matrix, ITF, Truncated PDF417, Micro QR code
- Media Type
- Receipt paper, paper tag, die cut labels, wristband labels
- Compatible Tapes
- RD tape
- Fonts
- Brussels, Helsinki, San Diego, Letter Gothic Bold
- Styles & Effects
- Bold, Mirror
- Black Mark sensor, gap sensor
- Networking
- Print server
- System Requirements
- Microsoft Windows XP, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2008, Windows 8, Microsoft Windows Server 2012
- 3-year warranty
- 11.1 cm x 21.5 cm x 17.2 cm
- Printer Type
- Label printer - direct thermal - monochrome
Printer
- Connectivity Technology
- Wired
- Interface
- 203 dpi
- Fonts
- Styles & Effects
- Bold, Mirror
- Auto Cutter
- Barcodes
RAM
- 6 MB
Media Handling
- Media Type
- Compatible Tapes
- RD tape
- Max Media Size
- Roll (6.3 cm)
- 19 mm
- 63 mm
- Media Sizes
- Roll (6.3 cm)
- Max Printing Width
- 56 mm
- Max Printing Length
- 1 m
- Media Thickness Range
- 0.058 mm - 0.279 mm
- Roll Maximum Outer Diameter
- 127 mm
- Roll Core Diameter
- 25.4 mm
- Networking
- Print server
- Connections
- 1 x RS-232 - 9 pin D-Sub (DB-9) , 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type A
- Cables Included
- 1 x USB cable
- Frequency Required
- 50/60 Hz
- Software Included
- Driver
- OS Required
- Limited warranty - 3 years
- 5 °C
- 40 °C
- 20 - 80% (non-condensing)
- 11.1 cm
- 21.5 cm
- 17.2 cm
- 1.34 kg
