Brother P-Touch TD2020 Label Printer
Quicklinx: 95YGWS00 Mfr#: TD2020ZU1
£84.89 ex VAT
£101.86 inc VAT
Designed for use in almost any retail work space, the TD-2020 is among the most compact and fastest 2.2-inch wide desktop thermal printers for retail applications. At 203dpi, it prints price, mark-down, product identification, returns and shelf-edge labels quickly at up to 6ips. Also prints tags and receipts for kiosk and POS applications. An innovative drop-in roll, spindle-less design helps make loading easy with existing or standard converted media.
  • Small size, but big on performance
    Although these printers are among the smallest desktop thermal printers in their class, they also lead in performance over many 203 dpi print resolution desktop thermal printers.
  • Ergonomic design
    Uses an innovative spindle-less design that accepts labels, tags or receipt media with virtually any core size for a true drop-in media roll loading experience on a desktop, cart or even mounted to a wall.
  • Adjustable edge-to-edge media sensor
    Flexibility to detect and print on more types of existing thermal media to help avoid converting custom media.
  • Print from a database
    Helps save time and increase accuracy by printing labels, tags and receipts linked directly to Microsoft SQL Server, Access or Excel database files.
Brother TD-2020 - label printer - B/W - direct thermal
Printer Type
Label printer - direct thermal - B/W
1.34 kg
Max Media Size
Roll (6.3 cm)
Min Media Size (Custom)
19 mm
Max Media Size (Custom)
63 mm
Max Resolution (B&W)
203 dpi
Cutter
USB 2.0, serial, USB host
RAM Installed (Max)
6 MB
Language Simulation
EPSON ESC/P, ZPL II, EPSON ESC/P Raster
Barcodes
Code 93, Code 39, UCC/EAN-128, QR code, MaxiCode, Aztec code, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, MicroPDF417, Codabar, Code 128, PDF417, Data Matrix, ITF, Truncated PDF417, Micro QR code
Media Type
Receipt paper, paper tag, die cut labels, wristband labels
Compatible Tapes
RD tape
Fonts
Brussels, Helsinki, San Diego, Letter Gothic Bold
Styles & Effects
Bold, Mirror
Black Mark sensor, gap sensor
Print server
Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista, Windows 8
3-year warranty
11.1 cm x 21.5 cm x 17.2 cm
Printer Type
Label printer - direct thermal - monochrome
Printer
Wired
203 dpi
Language Simulation
Fonts
Styles & Effects
Bold, Mirror
Auto Cutter
Barcodes
RAM
RAM Installed (Max)
6 MB
Media Handling
Media Type
Compatible Tapes
RD tape
Max Media Size
Roll (6.3 cm)
19 mm
63 mm
Media Sizes
Roll (6.3 cm)
Max Printing Width
56 mm
Max Printing Length
1 m
Media Thickness Range
0.058 mm - 0.279 mm
Roll Maximum Outer Diameter
127 mm
Roll Core Diameter
25.4 mm
Print server
1 x RS-232 - 9 pin D-Sub (DB-9) , 1 x USB 2.0 - 4 pin USB Type B , 1 x USB 2.0 - 4 pin USB Type A
1 x USB cable
Frequency Required
50/60 Hz
Software Included
Driver
Limited warranty - 3 years
5 °C
20 - 80% (non-condensing)
11.1 cm
21.5 cm
17.2 cm
1.34 kg
Brand: Brother
