Brother P-touch PT-P750W Wireless Labelling Machine
Quicklinx: 9NJNWS00 Mfr#: PTP750WZU1
Type: Printer
Functionality: Printer
Output Type: Monochrome
Wireless Capability: [N/A]
Technology: Thermal transfer
£108.74 ex VAT
£130.48 inc VAT
Professional label printing for the modern home and office
The P-touch P750W is an advanced yet easy-to-use Wi-Fi enabled labelling machine that everyone in your organisation can use to quickly design and print labels up to 24mm in width. Label file folders, archive documents, data backup discs/USB sticks and shelves, or create custom signage. P-touch Editor 5 software lets you use your PC's fonts, and include images, symbols and barcodes on your labels, or download the iPrint&Label app to design and print labels from your smartphone or tablet.
Key Features
  • Fast print speeds of up to 30mm/sec (when used with AC adapter)
  • Use as a portable device with optional Li-ion battery
  • Print labels 3.5 to 24mm in width.
  • Built-in Wi-Fi to share around the office.
  • Automatic cutter with half-cut option for easy-to-peel labels and reduced wastage.
  • Choose from any of your installed true type fonts.
  • Add a logo, symbol or frame to your labels.
  • Free iPrint&Label design app for your iOS and Android smartphone/tablet.
  • NFC reader to easily connect your NFC enabled mobile device.
Extra Features
  • Use as portable device, with optional li-ion battery.
  • Share label printing between many users.
  • Built-in auto cutter with full/half cut feature.
  • Includes tape cassette, AC adapter, USB cable.
  • Prints 3.5, 6, 9, 12, 18 and 24mm labels
P-touch laminated labels - designed to last
Brother P-touch laminated TZe tapes consist of six layers of materials, resulting in a thin yet extremely strong label. The thermal transfer ink is sandwiched between two protective layers of PET(polyester film), which protects the text against the effects of liquids, abrasion, temperature, chemicals and sunlight. As the labels have been tested to the extreme, you can be confident of a professional quality label that has been designed to last.
Clearly identify items with a durable P-touch label
Around the home, office, school, shop and other places of work, there are many uses for long lasting, durable P-touch labels. Common examples include:
  • Cables and plugs
  • CDs and DVDs
  • Office equipment
  • File folders
  • Staff and visitor name badges
  • Filing cabinets
  • Signage
  • Mail rooms
  • Notice boards
  • Shelving
  • Telephone extension numbers
Brother P-Touch PT-P750W - label printer - B/W - thermal transfer
Printer Type
Label printer - thermal transfer - B/W
800 g
Max Media Size
Roll (2.4 cm)
Max Media Size (Custom)
24 mm
Print Speed
Up to 30 mm/sec
Cutter
USB 2.0, Wi-Fi(n), NFC
Media Type
Laminated tape
Compatible Tapes
TZe tape
Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2008, Windows 8, Microsoft Windows Server 2012, Apple MacOS X 10.8.x, Microsoft Windows Server 2012 R2, Windows 8.1, Apple MacOS X 10.7.5, Apple MacOS X 10.9.x
7.8 cm x 15.2 cm x 14.3 cm
Printer Type
Label printer - thermal transfer - monochrome
Printer
Print Speed
Up to 30 mm/sec
Cutter
Repeating Printing
5000 copies
Media Handling
Media Type
Laminated tape
Compatible Tapes
TZe tape
Max Media Size
Roll (2.4 cm)
24 mm
Media Sizes
Roll (2.4 cm), Roll (0.6 cm), Roll (1.8 cm), Roll (1.2 cm), Roll (0.9 cm), Roll (0.35 cm)
Max Printing Width
18.1 mm
Media Feeders
1 x manual - 1 roll - Roll (2.4 cm)
1 x USB 2.0
2 x USB cable
Media Included
1 24 mm x 4 m black on white TZe tape cassette
Power adapter - external
7.8 cm
15.2 cm
14.3 cm
800 g
Ink (17)
9NJN Brother TZES221 Black on White 9mm In Stock £10.87
9NJN Brother TZe-S211 - laminated tape - 1 cassette(s) - Roll (0.6 cm x 8 m) In Stock £9.51
9NJN Brother TZE-651 24MM BLACK ON YELLOW In Stock £16.67
9NJN Brother TZe-241 - laminated tape - 1 cassette(s) - Roll (1.8 cm x 8 m) In Stock £11.14
9NJN Brother TZES651 24mm Black on Yellow In Stock £15.10
9NJN Brother Laminated Tape 12mm Blk on Yel In Stock £9.30
9NJN Brother Tape Black on Yellow 6mm In Stock £7.48
9NJN Brother TZE-335 LAMINATED TAPE 12MM 8M In Stock £11.14
9NJN Brother Tape Black on Yellow 12mm In Stock £11.40
9NJN Brother Black On Clear Labelling Tape 12mm In Stock £8.41
9NJN Brother 12mm Black on White Tape In Stock £11.40
9NJN Brother Tape Black on Clear 9mm In Stock £7.48
9NJN Brother 12mm Matt Black on Red Laminated Tape In Stock £9.85
9NJN Brother TZESE4 Black on White 18MM Security Tape In Stock £26.24
9NJN Brother 12mm Blue on White Tape In Stock £9.85
9NJN Brother P-touch TZe-211 (6mm x 8m) Black On White Label Tape In Stock £7.80
9NJN Brother TZE621 9MM GLOSS Black on Yellow Tape In Stock £8.41
Other bundles (1)
9NJN Brother TZe 231 - laminated adhesive tape - 1 roll(s) In Stock £9.70
Type: Printer
Max Print Speed: [N/A]
Max Paper Size: Roll (2.4 cm)
Brand: Brother
