Design and print impressively durable labels from your Mac, Windows PC or right from the palm of your hand with the PT-H500.
Adding images, frames and barcodes to your labels is simple with direct USB connection to your computer, and you can also create stylish text using the installed True Type fonts.
Thanks to its handheld design, the P-touch H500 can also help you organise your office quickly and easily on the go by allowing you to instantly create labels to identify file folders, archived documents, data USB sticks and shelves.
- Brother P-Touch PT-H500 - labelmaker - B/W - thermal transfer
- Printer Type
- Labelmaker - thermal transfer - B/W
- Form Factor
- Portable
- 830 g
- Max Media Size
- Roll (2.4 cm)
- Print Speed
- Up to 30 mm/sec
- Max Resolution (B&W)
- 180 dpi
- Cutter
- Interface
- USB 2.0
- Media Type
- Laminated tape
- Compatible Tapes
- TZe tape
- Fonts
- 14 fonts
- Character Sizes
- 9 points, 6 points, 42 points, 36 points, 24 points, 18 points, 12 points, 48 points
- Styles & Effects
- Bold, italic bold, italic outline, italic shadow, solid, normal, vertical, outline, shadow, italic, Mirror, italic solid
- 7 line printing
- Display Resolution
- 2 lines x 16 characters / 128 x 64
- Keyboard
- QWERTY
- Battery
- Required 6 x AA type Included Qty 0
- System Requirements
- Microsoft Windows 7, Microsoft Windows Vista, Windows 8, Apple MacOS X 10.6 - 10.8
- 12.1 cm x 24.7 cm x 8.9 cm
- Printer Type
- Labelmaker - thermal transfer - monochrome
Printer
- Print Speed
- Up to 30 mm/sec
- Built-in Devices
- Preview screen, character keyboard
- Interface
- USB 2.0
- 180 dpi
- Fonts
- 14 fonts
- Character Sizes
- Styles & Effects
- 7 line printing
- Cutter
- Keyboard
- QWERTY
- Repeating Printing
- 99 copies
- Fonts Included
- 1 x barcode
Media Handling
- Media Type
- Laminated tape
- Compatible Tapes
- TZe tape
- Max Media Size
- Roll (2.4 cm)
- Media Sizes
- Roll (2.4 cm), Roll (0.6 cm), Roll (1.8 cm), Roll (1.2 cm), Roll (0.9 cm), Roll (0.35 cm)
- Connections
- 1 x USB 2.0
- Included Accessories
- Wrist strap
- Cables Included
- 1 x USB cable
- Media Included
- 1 24 mm x 4 m black on white TZe laminated tape cassette
- Power Device
- No power supply
- AA type
- Required Qty
- 6
- Included
- 0
- OS Required
- 10 °C
- 35 °C
- 20 - 80% (non-condensing)
- 12.1 cm
- 24.7 cm
- 8.9 cm
- 830 g
- Width (Shipping)
- 30.3 cm
- Depth (Shipping)
- 30.1 cm
- Height (Shipping)
- 12.4 cm
Ink (19)
Brother TZES221 Black on White 9mm | In Stock | £7.06 |
Brother TZe-S211 - laminated tape - 1 cassette(s) - Roll (0.6 cm x 8 m) | In Stock | £9.83 |
Brother TZE-651 24MM BLACK ON YELLOW | In Stock | £16.80 |
Brother TZe-241 - laminated tape - 1 cassette(s) - Roll (1.8 cm x 8 m) | In Stock | £10.82 |
Brother TZES651 24mm Black on Yellow | In Stock | £15.61 |
Brother Laminated Tape 12mm Blk on Yel | In Stock | £9.12 |
Brother Tape Black on Yellow 6mm | In Stock | £7.72 |
Brother TZE-335 LAMINATED TAPE 12MM 8M | In Stock | £11.24 |
Brother Tape Black on Yellow 12mm | In Stock | £11.03 |
Brother Black On Clear Labelling Tape 12mm | In Stock | £8.69 |
Brother 12mm Black on White Tape | In Stock | £11.78 |
Brother Tape Black on Clear 9mm | In Stock | £7.72 |
Brother 12mm Matt Black on Red Laminated Tape | In Stock | £10.18 |
Brother TZESE4 Black on White 18MM Security Tape | In Stock | £24.39 |
Brother 12mm Blue on White Tape | In Stock | £10.18 |
Brother P-touch TZe-211 (6mm x 8m) Black On White Label Tape | In Stock | £7.53 |
Brother TZE621 9MM GLOSS Black on Yellow Tape | In Stock | £8.69 |
Brother BRO 24MM GLOSS TZ BLACK ON RED TAPE | In Stock | £17.23 |
Brother TZEFX-231 Black On White Flexi Tape | In Stock | £11.78 |
Other bundles (1)
Brother TZe 231 - laminated adhesive tape - 1 roll(s) | In Stock | £9.61 |
