Brother P-Touch PT-H500 Handheld Labelling Machine
Quicklinx: 9K2MWS00 Mfr#: PTH500
Type: Printer
Functionality: Printer
Output Type: Monochrome
Wireless Capability: [N/A]
Technology: Thermal transfer
£66.19 ex VAT
£79.42 inc VAT
Design and print impressively durable labels from your Mac, Windows PC or right from the palm of your hand with the PT-H500.
Adding images, frames and barcodes to your labels is simple with direct USB connection to your computer, and you can also create stylish text using the installed True Type fonts.
Thanks to its handheld design, the P-touch H500 can also help you organise your office quickly and easily on the go by allowing you to instantly create labels to identify file folders, archived documents, data USB sticks and shelves.
Brother P-Touch PT-H500 - labelmaker - B/W - thermal transfer
Printer Type
Labelmaker - thermal transfer - B/W
Portable
830 g
Max Media Size
Roll (2.4 cm)
Print Speed
Up to 30 mm/sec
Max Resolution (B&W)
180 dpi
Cutter
USB 2.0
Media Type
Laminated tape
Compatible Tapes
TZe tape
Fonts
14 fonts
Character Sizes
9 points, 6 points, 42 points, 36 points, 24 points, 18 points, 12 points, 48 points
Styles & Effects
Bold, italic bold, italic outline, italic shadow, solid, normal, vertical, outline, shadow, italic, Mirror, italic solid
7 line printing
Display Resolution
2 lines x 16 characters / 128 x 64
Keyboard
QWERTY
Required 6 x AA type Included Qty 0
Microsoft Windows 7, Microsoft Windows Vista, Windows 8, Apple MacOS X 10.6 - 10.8
12.1 cm x 24.7 cm x 8.9 cm
Printer Type
Labelmaker - thermal transfer - monochrome
Printer
Print Speed
Up to 30 mm/sec
Built-in Devices
Preview screen, character keyboard
USB 2.0
180 dpi
Fonts
14 fonts
Character Sizes
Styles & Effects
7 line printing
Display Resolution
Cutter
Keyboard
QWERTY
Repeating Printing
99 copies
Fonts Included
1 x barcode
Media Handling
Media Type
Laminated tape
Compatible Tapes
TZe tape
Max Media Size
Roll (2.4 cm)
Media Sizes
Roll (2.4 cm), Roll (0.6 cm), Roll (1.8 cm), Roll (1.2 cm), Roll (0.9 cm), Roll (0.35 cm)
1 x USB 2.0
Wrist strap
1 x USB cable
Media Included
1 24 mm x 4 m black on white TZe laminated tape cassette
No power supply
AA type
Required Qty
6
Included
0
10 °C
35 °C
20 - 80% (non-condensing)
12.1 cm
24.7 cm
8.9 cm
830 g
Width (Shipping)
30.3 cm
Depth (Shipping)
30.1 cm
Height (Shipping)
12.4 cm
Ink (19)
9K2M Brother TZES221 Black on White 9mm In Stock £5.88
9K2M Brother TZe-S211 - laminated tape - 1 cassette(s) - Roll (0.6 cm x 8 m) In Stock £9.83
9K2M Brother TZE-651 24MM BLACK ON YELLOW In Stock £16.10
9K2M Brother TZe-241 - laminated tape - 1 cassette(s) - Roll (1.8 cm x 8 m) In Stock £10.79
9K2M Brother TZES651 24mm Black on Yellow In Stock £15.61
9K2M Brother Laminated Tape 12mm Blk on Yel In Stock £9.07
9K2M Brother Tape Black on Yellow 6mm In Stock £7.72
9K2M Brother TZE-335 LAMINATED TAPE 12MM 8M In Stock £11.31
9K2M Brother Tape Black on Yellow 12mm In Stock £11.12
9K2M Brother Black On Clear Labelling Tape 12mm In Stock £8.69
9K2M Brother 12mm Black on White Tape In Stock £11.78
9K2M Brother Tape Black on Clear 9mm In Stock £7.72
9K2M Brother 12mm Matt Black on Red Laminated Tape In Stock £10.18
9K2M Brother TZESE4 Black on White 18MM Security Tape In Stock £20.11
9K2M Brother 12mm Blue on White Tape In Stock £10.18
9K2M Brother P-touch TZe-211 (6mm x 8m) Black On White Label Tape In Stock £7.58
9K2M Brother TZE621 9MM GLOSS Black on Yellow Tape In Stock £8.69
9K2M Brother BRO 24MM GLOSS TZ BLACK ON RED TAPE In Stock £17.23
9K2M Brother TZEFX-231 Black On White Flexi Tape In Stock £11.78
Other bundles (1)
9K2M Brother TZe 231 - laminated adhesive tape - 1 roll(s) In Stock £9.61
Type: Printer
Max Print Speed: [N/A]
Max Paper Size: Roll (2.4 cm)
Brand: Brother
