Brother P-Touch PT-1010 - labelmaker - B/W - thermal transfer
Quicklinx: 7VP4WS00 Mfr#: PT1010ZU1
The PT-1010 is a portable electronic labeller featuring separate keypads - one numerical and one alphabetical, making data entry so much easier. The PT-1010 is easy to use and versatile. It has a large 12-character LCD display, ABC and 123-style keyboard and is powered by adaptor (optional) or batteries. You can choose from five type sizes, nine type styles, underline and framing options and the flexibility of printing up to 2 lines of text.
Printer Type
Labelmaker - thermal transfer - B/W
Portable
365 g
United Kingdom
Max Media Size
Roll (1.2 cm)
Max Media Size (Custom)
12 mm
Print Speed
Up to 10 mm/sec
Max Resolution (B&W)
180 dpi
Cutter
Media Type
Non-laminated tape, flexible tape, laminated labels, fabric iron-on tape
Compatible Tapes
TZ tape
Fonts
Helsinki
Character Sizes
9 points, 6 points, 24 points, 18 points, 12 points
Styles & Effects
Bold, italic bold, italic outline, italic shadow, normal, vertical, outline, shadow, italic, Mirror, underline, frame
2 line printing
Display Resolution
1 line x 12 characters
Keyboard
ABCD / 51 keys
Required 6 x AAA type Alkaline
Enclosure Colour
Black, silver
3-year warranty
10.7 cm x 20.3 cm x 5.7 cm
Printer Type
Labelmaker - thermal transfer - monochrome
Enclosure Colour
Black, silver
United Kingdom
Printer
Print Speed
Up to 10 mm/sec
Built-in Devices
Preview screen, character keyboard, cutter
180 dpi
Fonts
Helsinki
Character Sizes
Styles & Effects
2 line printing
Display Resolution
Cutter
Keyboard
ABCD / 51 keys
Repeating Printing
9 copies
Media Handling
Media Type
Compatible Tapes
TZ tape
Max Media Size
Roll (1.2 cm)
12 mm
Media Sizes
Roll (0.6 cm), Roll (1.2 cm), Roll (0.9 cm), Roll (0.35 cm)
Max Printing Width
9 mm
Max Printing Length
300 mm
AAA type - Alkaline
Required Qty
6
Limited warranty - 3 years - carry-in
10.7 cm
20.3 cm
5.7 cm
365 g
