The versatile GL-H105VP label printer (including carry case) fits comfortably in your hand and is straightforward and easy to use.
You can create labels for everything from your spring and summer bulbs to your shelving in next to no time. With its range of symbols and font styles, such as italics and quote marks, gardeners can easily bring the professional touch to plant labelling. This clever machine can also store up to nine names in its memory too – particularly useful for those difficult to spell plant names.
So whether you choose to use it in the home or garden (or both), you'll soon find the GL-H105VP indispensable.
- Brother P-Touch GL-H105VP - labelmaker - B/W - thermal transfer
- Printer Type
- Labelmaker - thermal transfer - B/W
- Form Factor
- Portable
- 420 g
- Max Media Size
- Roll (1.2 cm)
- Print Speed
- Up to 20 mm/sec
- Max Resolution (B&W)
- 180 dpi
- Cutter
- Media Type
- Laminated tape
- Compatible Tapes
- TZe tape
- Fonts
- Helsinki
- Styles & Effects
- Bold, italic bold, italic outline, italic shadow, normal, vertical, outline, shadow, italic, underline
- Display Resolution
- 1 line x 12 characters
- Keyboard
- ABCD / 54 keys
- Battery
- Required 6 x AAA type
- 3-year warranty
- 11 cm x 20.7 cm x 5.9 cm
- Printer Type
- Labelmaker - thermal transfer - monochrome
Printer
- Print Speed
- Up to 20 mm/sec
- Built-in Devices
- Preview screen, character keyboard
- 180 dpi
- Fonts
- Helsinki
- Styles & Effects
- Cutter
- Keyboard
- ABCD / 54 keys
Media Handling
- Media Type
- Laminated tape
- Compatible Tapes
- TZe tape
- Max Media Size
- Roll (1.2 cm)
- Media Sizes
- Roll (0.6 cm), Roll (1.2 cm), Roll (0.9 cm), Roll (0.35 cm)
- Media Included
- 1 12 mm x 4 m black on white strong adhesive laminated tape (TZeS231)
- Power Device
- Power adapter
- AAA type
- Required Qty
- 6
- Limited warranty - 3 years
- 11 cm
- 20.7 cm
- 5.9 cm
- 420 g
